Soul in a Jar
1,388
11
Published
Introduction: Soul in a Jar
About: My name is Zach Sousa and I'm a Canadian highschool student that has a passion for making.
In this instructable I will show you how to make a soul in a jar. A soul in a jar Is a laser engraved jar with blinking and fading leds that make the laser engraved face look illuminated.
Step 1: Parts and Tools
Here are the parts and tools needed to make this project:
Small glass jar that can fit in a laser cutter
At tiny 85
Arduino Uno for programming
Small circuit board that fits through hole in the top of the jar
Laser cutter
Soldering iron
Solder
2 LEDs any colour will work I used yellow
Computer with Arduino IDE
4 pin chip socket for at tiny 85
Wire
Cr2032 battery
Cr2032 battery holder (if you dont have one you can 3d print one)`
Step 2: Laser Engrave Jar
Using a laser cutter engrave this picture on the glass jar:
Step 3: Solder Circuit
First solder the 8 pin socket to the circuit board. Then solder the LEDs as shown in the first picture. Make sure to remember which lead is positive and which one is negative. Solder the two negative leads to each other and solder them to the pin that goes to the at tiny's ground pin (pin 4) . Solder circuit as shown in the schematic.
Step 4: Drill Hole Through Cork
Measure the diameter of each of the wires and add the diameters together and use a drill bit slightly larger than that. Drill out the hole in the middle of the cork and put 2 wires through the cork these wires will connect to the battery pack.
Step 5: Wire Battery Pack
Hot glue the cr2032 battery pack to the cork and solder the negative lead of the battery pack to the at-tiny pin 4 (ground). Then solder the positive lead of the battery pack to the at-tiny pin 8 (voltage in)
You can 3d print a battery pack if you dont have one. Here is a link to one that works great:
http://www.thingiverse.com/thing:280985
Step 6: Program Arduino
View my other instructable to program the attiny:
https://www.instructables.com/id/How-To-Program-An-...
Use the arduino sketch below:
Step 7: Done!
Thank you for viewing this instructable and if you liked it please vote for it in contests favorite it and subscribe!
Share ideas of what kind instructables I can make like a theme or a specific project!
If you had trouble with this instructable in any way tell me what you didn't understand and I can help you.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    3 Comments
    Great idea! A video will be up in about 5-10 minutes!
