loading
Step 7: Final Assembly
Get your friends and family together, and record the sounds, we did a combination of sweet and silly ones.
1) decide which sound should go where
2)  Lay out your wire assembly on top of the quilt to help you visualize where the wires will go.
3) Place the battery compartment holder  between the back of the fabric and the smaller fabric square.
4) Cut a slit from the side, though a bit of the fabric square and ONE layer of the batting. Run your wire through that slit.
5) Layout all of the sound buttons between the 2 layers of batting, keep their wires from getting tangles, and remember you want one under each square.
6) Put a safety pin through the quilt where the wires cross from one square to the next, be sure to get the wires inside the safety pin.
7) Top stitch around the quilt, and between all the rows and columns.  Be careful not to stitch through any wires. I found I could feel them fairly easily. When you come to a safety pin.... back stitch for a couple pf stitches, and then lift up your needle, and start sewing again on the other side of the pin. It's a good idea to back stitch on that side as well.
8) remove all the safety pins
9) Sew the last side closed by hand.
Yeah!!!
Good for you, your husband's grand father looks happy as can be with his new quilt. You should be proud of yourself!
He really was :-) <br>And family really liked helping making all the sounds!<br>Thank you.
thats amazing!
i hope you wil win the contest!
I don't make quilts and barely sew, but I was looking through the competition for this month's contest and read your beautifully written Instructable. It is easy to understand, has great photos and seems complete in every detail. More importantly, it was done for the right reasons.<br><br>The best of luck to you in the Monthly Challenge.
Thank you SOOOO much for that comment. I try hard to make these projects fun &amp; reproducible, and often wonder, how well I've managed. :-)
This is wonderful! Nicely done. <br><br>Though I don't believe what you say about soldering ;)
I didn't either till I tried it ... :)<br>Thank you.<br>
About This Instructable
5,867views
31favorites
License:
More by AlpineButterfly:Sound Quilt Inspiring Muse from a Bike Wheel Recycled Monster
Add instructable to:
