Sound Ranging for the Visually Impaired Using Arduino Prototype Design Concept
Published
Introduction: Sound Ranging for the Visually Impaired Using Arduino Prototype Design Concept
This was my idea for a device that would assist the visually impaired using an ultra-sonic ranging sensor mounted on a hat.  Basically the concept is that the device would tone out distances for a visually impaired person allowing them to essentially see with their ears.  The Utlra-sonic sensor sends out a ping and based on the time it takes to receive the ping back, can calculate distances of nearby objects/ surfaces.  The Arduino translates this distances into distinguishable audio tones variations.  Different tones indicate different distances, a fast stacatto tone indicates an object is very near where as a single short burst high tone indicates a greater distance to an object.
Step 1:
Basically the unit consists of an Ultrasonic Sensor, and Arduino Uno, and a piezo buzzer.  To start I used an old headlamp band and created a flat surface to mount the prototype housing on.   Next I mounted the battery and Arduino in an old project case.  I drilled all holes with a cordless dremel, mounted the Uno and Battery inside the project case.  With the Ultrasonic Sensor, I soldered this to a small bread board and mounted the board to a paper holder which fits nicely on the brim of my hat!
Parts List:
1 x Arduino Uno
1 x Ultrasonic Sensor and library (http://iteadstudio.com/?dl_id=7)
1 x Piezo Buzzer
1 x 9 volt batter with Arduino Connector
Step 2: Tone Demonstration and Source Code
//Vcc to 5 volt +
//Trig to pin 12
//Echo to pin 13
//Grd to Grd
//Piezo to pin 9
//GRD to GRD
#include "Ultrasonic.h"
Ultrasonic ultrasonic(12,13);  //12,13 are pin assignements
int buzzPin = 9;  // positive connection of the piezo
int delay1 = 25;
void setup() {
Serial.begin(9600);
void loop()
  Serial.print("cm     :");
  Serial.print(ultrasonic.Ranging(CM));
  Serial.println("");
    //delay(100);
  if(ultrasonic.Ranging(CM) > 0 && ultrasonic.Ranging(CM) <= 5)
   { tone(buzzPin, 100 ,100); delay(100);}
  if(ultrasonic.Ranging(CM) > 5 && ultrasonic.Ranging(CM) <= 10)
   {tone(buzzPin, 100 ,100); delay(100);}
  if(ultrasonic.Ranging(CM) > 10 && ultrasonic.Ranging(CM) <= 20)
   {tone(buzzPin, 15 ,100); delay(50);}
  if(ultrasonic.Ranging(CM) > 20 && ultrasonic.Ranging(CM) <= 30)
   {tone(buzzPin, 14 ,100); delay(50);}
  if(ultrasonic.Ranging(CM) > 30 && ultrasonic.Ranging(CM) <= 40)
   {tone(buzzPin, 13 ,100); delay(50);}
  if(ultrasonic.Ranging(CM) > 40 && ultrasonic.Ranging(CM) <= 60)
   {tone(buzzPin, 12 ,100); delay(50);}
  if(ultrasonic.Ranging(CM) > 60 && ultrasonic.Ranging(CM) <= 90)
   {tone(buzzPin, 11 ,100); delay(050);}
  if(ultrasonic.Ranging(CM) > 90 && ultrasonic.Ranging(CM) <= 120)
   {tone(buzzPin, 10 ,100); delay(50);}
  if(ultrasonic.Ranging(CM) > 120 && ultrasonic.Ranging(CM) <= 200)
   {tone(buzzPin, 9 ,100); delay(50);}
   {tone(buzzPin, 8 ,150); delay(50);}
  if(ultrasonic.Ranging(CM) > 200 && ultrasonic.Ranging(CM) <= 300)
   {tone(buzzPin, 9000 ,150); delay(50);}
Step 3: Limitations and Design Improvements
Of course this being a prototype, there are some lacking areas.  First off size is a major issue, no one likes walking around with 10 pounds of electronics on their hat.  Ideally this unit would be programmed on an ATTiny and be small enough to clip on to a shirt collar.  Perhaps it could be incorporated into a pair of sunglasses.  Also, a push button in a person's pocket would allow them to 'Tone on Demand' reducing the constant tone.  Finally an ear-bud audio device as opposed to a piezo buzzer would allow for more discrete toning.
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    10 Comments
    I was able to find Ultrasonic.h at Github. When you compile, the IDE will say it can't find WProgram.h. The only way to fix that error is go into Ultrasonic.h and Ultrasonic.cpp and change WProgram.h to Arduino.h. Make the edit and save. After that it will work.
    To make it work, we need the library Ultrasonic.h. Where might I get that?
    can i attach playback sound module instead of pizzo buzzer
    Code doesn't work. Arduino IDE throws an error when you Verify the code and says "Ultrasonic does not name a type".
    code worked ? or any alternative?
    are there any further instructions regarding this project? I really like it and I would like to try one! :)
    If you do decide to further develop this system, I have one further suggestion - get it off the user's head. Sighted individuals use their heads because that's where their eyes are - but putting your sensors on the end of a guidecane or wand would probably be more effective for the visually impaired.
    Mind you, I'm sighted so I may not know what I'm talking about. However, it seems obvious to me that putting the range sensor on an extremity would make it more useful/less risky for the user.
    sir can you post the schematic diagram??of the circuit.thanks a lot
