Sound Reactive Strip Led
3,049
46
7
Posted
Introduction: Sound Reactive Strip Led
Hello,in this instructables I will show you how to control a led strip with music!. I put this led strip in my room,near my Playstation 4 and my speakers, so I created also an amazing illuminated gaming station. This led strip reacte when there is music,or simply a sound. In fact I use it also when I play videogames:while I'm shooting in a action videogames, the leds reacte and the result is amazing. In the final step there is a link that show the final result. Check the next steps!
Step 1: What You Will Need:
- LED strip
-Arduino uno
- sound module
-relè
- 9v battery/powerbank
- some wires
-adaptor to power the strip
Step 2: Wiring
Sorry for the quality of the image ,but I had many problems with the fritzing sketch. There is a file attached in this step so you can download the sketch for a better quality of the scheme. In the sketch I idn't find a sound sensor so I took a casual sensor that rappresent the module.
Sound sensor:
The first pin is the signal: S>digital pin 7
The second pin is the voltage: V> 5v pin
The third is the ground: G> gnd pin
Step 3: The Code
#define LEDstrip 9
void setup()
{ pinMode(7,INPUT);
pinMode(LEDstrip, OUTPUT);
.void loop()
{ boolean soundstate = digitalRead(7);
if (soundstate == 1) {
analogWrite(LEDstrip, 255);
delay(10);
else{
analogWrite(LEDstrip,0); }
Step 4: Turn Up the Speakers!!!
The project is finish!!! In only 4 steps I show you how to make a " disco" in your room with "disco light". Now you have almost finish....the only thing you need to do is...TURN UP THE SPEAKERS AND DANCE!
I hope you liked this project,comment and see you next time!
Here there is the link for the final result:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
7 Comments
please make for rgb leds one...
and dont put the extra info IN THE REPLY`S.
then do nothing.
make the IBLE better and put it in there.!
thanks for the criticism , I will improve myself about making instructables
verry bad IBLE, sorry
its a nice one if you realy took time and efford,you clearly see this is a quicky, of a already working build.
sorry friend,but we al must help eachoter,so dont take it to hard and do your magic
where should the power plug go and where should I hook up the relay? could you please send me some close up pictures of your setup
Could you be more specific than "Sound module"? That's not very helpful. And is that a solid state relay or mechanical?
Ehy I'm sorry for the misunderstanding. Here there is a link that show you the sound sensor and rele on amazon so you can understand better what tipe of sensor are. RELE: https://www.amazon.com/gp/aw/d/B0057OC6D8/ref=mp_s_a_1_2?ie=UTF8&qid=1473604775&sr=8-2&pi=SY200_QL40&keywords=rele+arduino&dpPl=1&dpID=51eyw8a9hKL&ref=Patch
SOUND SENSOR: https://www.amazon.com/gp/aw/d/B00TM7R21W/ref=mp_s_a_1_2?ie=UTF8&qid=1473604957&sr=8-2&pi=SY200_QL40&keywords=sound+sensor&dpPl=1&dpID=310aOap-TwL&ref=plSrch
