Sound Recording @ Zero Noise
1,908
28
8
Published
Introduction: Sound Recording @ Zero Noise
About: #Design aspirant #Hobbyist #Engineer #Radical Design Ideas
Hi, this is an instructable which solves the problem of sound recording in general room environment. Have you ever faced trouble in recording videos/live lectures/conversations/television programs using a screen recorder and mic. generally we do face trouble with others speaking around the mic, vehicular noises, air buzzing and what not even the slightest of the slightest body tapping movements.
So, I have come up with an idea to solve this issue by using simple acoustics damping materials which we see around daily in our house. These materials don't even costs much and this project was build with not just more than INR 200₹ / USD 3$.
So lets start Building it........
Step 1: Materials & Tools Required
Materials
1. 8 ohms small Speaker - 1 No.s
2. Mic - 1 No.s
3. Deo/Spray Caps (plastic) - 2 No.s
4. Aux Cable - 1 No.s
5. Surgical Cotton - 200 Gms
6. Sponge (Foam) - 30 * 25 * 20 Cms
7. Cardboard box - 25 * 20 * 10 Cms
Tools
1. Hawk saw Blade
2. Scissors
3. Cello Tape
4. Cutter
5. Fevicol (white glue)
6. Synthetic glue
7. Soldering Gun and Lead
8. Multimeter
9. Ruler
10. Tweezer
Step 2: Assembling the Speaker & Mic
1. First take the Aux cable which is equipped with two sided 3.5mm jack pin. Cut the wire exactly in the middle length as shown in the picture.
2. Now take the two spray/deodorant bottle caps and make a small hole such that the aux cable can be inserted using the heated soldering rod.
3. Now insert the cables into each cap and solder the mic to one of the wires and a speaker to the other.
4. Each cable has three wires (a ground, right and left pins respectively), short the right and left pin wires and forming a two wired cable.
5. Now using the multimeter, Put it on the continuity setting and check now which terminal is which on a microphone. Place one multimeter probe on the outside metallic casing of the microphone. And place the other multimeter probe on one of the two terminals on the top of the microphone.
If the multimeter beeps, signaling continity, then the terminal you are on is the negative or ground terminal. If the multimeter doesn't beep, signaling discontinuity, then the terminal you are on is the positive terminal of the microphone.
6.Similarly in the three segments of the 3.5mm jack the last segment which is close to the wire end is the negative terminal. place one multimeter probe at the third segment of the pin and other at one end of a wire, the one that beeps is the negative wire.
7. A speaker usually can be wired irrespective of polarity. so solder two wires with the aux cable and test if everything is working fine.
Step 3: Testing and Capsule Enclosure
Pre-Testing
1. Once the mic and speaker is soldered to aux cable, they are to be checked if they are properly functioning. To find out plug the mic cable into laptops mic (red) socket and go to Control Panal > click on Speech Recognition > Select Start Speech Recognition > Speak into the mic and see whether the level is fluctuating as you speak.
If every thing is fine, the mic is ready for the use.
2. Similarly plug in the speaker cable into the Speaker(black/green) port of the laptop and play a sound clip and if the sound emits from the speaker inserted then it should be working fine and pre-testing is done.
Capsule Enclosure
1. Once the testing is done, Insert some surgical cotton into the both the caps and secure the mic and speaker such that they both sit properly and glue it with fevicol.
2. Once they are glued allow them to rest and after setting, seal the mouths of both the caps using synthetic glue
(Note: See that there is a little gap in between the speaker and mic inside the sealed caps. They should not touch each other and a air gap is mandatory.)
3. Once the caps are sealed, Roll the Capsule in a thick sheet of Cotton bundle. here cotton acts as a Acoustic absorption material so that any kind of unwanted vibrations are absorbed inside and no buzz sound is created in the recording.
Step 4: Final Sealing Using Sponge Foam Sheets
Inserting Capsule into Cardboard Box
1. Once the Capsule is ready then take the cardboard box and insert some cotton and then place the capsule and secure it in such a way that it doesn't moves when shaken. fill the gaps of the cardboard completely with cotton and punch two holes on to one side of the box and take out the aux cables from those holes.
2. Once this is done seal the whole box using a duct tape such that no air goes in or out.
Layering of Sponge sheets
1. Now take the Sponge cube and cut accordingly into 3 cms thick sheets.
2. Once the sheets of sponge are cut out using the hawk saw blade, stick each sheet using the glue on to each side of the card board box and completely cover it using the sponge sheets.
Here the sponge foam sheets act as Acoustic dampers, which obstructs external noises into entering into the cardboard box such that no noise is affecting the sound quality.
Step 5: Final Output
Once all the steps are done here is the final recording cube. For final Testing I have recorded a video in a much noisy environment and even in a home theater setup and the results are pretty good.
No noise/external sounds are heard in the recording...... Now that's how you can record any stuff using this small recording cube... Thank you !! Have fun !! Stay Creative !!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    8 Comments
    Yep, the logic seems to be simple but the whole setup creates an environment such that no external noises enter into your recordings. :)
    The final device looks very nice, and I like the multiple layers of insulation, but why not use the auxiliary cable by itself?
    thanks, Initially I too got the same idea of using the aux cable to plug in between the mic and headphones jacks and tried it, but the result was nothing but a buzz sound. I later figured it out how a mic condenser works and how a headphone jack output works, they are far different and it is impossible to use it in that way.
    That's interesting! With my computer I am able to plug a cord directly from the headphone jack to the microphone jack and record audio - I think my laptop has an internal adjustment so instead of expecting a microphone it reads as a "Line In."
    It took me a bit to understand, but this is a very creative solution. I also happen to have a number of condenser mics sitting in a drawer somewhere, so this might be a good first project with them.
    Not sure I understand how this works. Is it noise cancellation?
    To make it simple this setup is a kinda noise cancellation equipment but which can be used only for screen/video recording. I once faced a problem recording a live video lecture in room environment, so I have come up with this idea and it was effective and solved the problem and thought so..as many would face the same so made this instructable.
    Shouldn't there be a delay line involved or am I over thinking this?
