Step 4When life isn't ideal....
To test an audio circuit using the above tools, you need to have a working microphone circuit. i hooked my oscilloscope to the output of the mic circuit then just talked into it to make sure that the microphone was actually “hearing” it. You should see the level increase as you talk into the mic and go down as silence takes over. Once i was sure my mic circuit worked, i fed the output of the mic into the input of the filter i was testing and moved my oscilloscope test point to the filter output. this time instead of talking into it i used the sweep function of the frequency generation program. make sure and set your sweep time high (relatively for an oscilloscope) i chose 2 seconds. since your sweeping threw the selected frequency range while maintaining the same volume level, any differences you see in amplitude are differences in amplification at those frequency's. you should see some sort of "high point". this is when i discovered that my circuits were not filtering for the frequency’s i had thought, however they were performing as band pass filters. i was basically using an arrow head shape.
Add Comment
