Step 5Bring in reinforcements!
Center holes. Drill a clearance hole on all the disks for the threaded rod your using. The smaller the threaded rod the better the airflow through the overlap. There is a purpose to the 18.7% overlap. That is so as the wind pushes on the facing can, some of the air flows through the overlap and pushes back on the other can, adding power and compensating slightly for the wind pushing on the back side of the other can.
Time for the glue. I used Gorilla Glue since its expanding and strong for a wide range of materials and I had it laying around. If using Gorilla Glue, probably need some water spritzed on the cans since theyre not porous. You can tack some short finish nails at an angle through the cans or some small screws. Might need to punch a hole before nailing to finished product. Let glue dry for as long as it says on the bottle.
Add Comment
