3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sourcing Rare Earth Magnets
Looking for cheap rare Earth magnets? I picked up this set of eBay for under $15 and it contains 188 of these little (but very strong) magnets and three dozen steel balls. Hopefully this gets more people into the magnetic challenge. I'll be posting my $1 digital counter/odometer/much more within a few days (and finally enter the challenge :D).
Simply grasp one end of a bar with pliers and squeeze. Then touch the bar to something magnetic such as a ferrous pair of pliers :P The idea is to deform the casing slightly which allows the magnet to pop out. Mine were only pressed in - no glue.
Be careful when putting them together - they are capable of self destruction if you snap them together. And once they are together -- its a PITA to get them apart (I used pliers ;) ).
Yes, I know you can find magnets around for free.... but if you can find this quantity/quality - I'd be impressed.
38 comments
Aug 31, 2011. 3:30 PMpgd5000 says:
I wish i would have seen this a year ago, i had one of these filled to the point it would not close, but i had to throw it away :(
Jul 7, 2007. 12:07 AMsuper_genius says:
I HAVE A BETTER IDEA!!! I LIVE IN A TOWN WHERE AT THE DOLLAR STORES THEY HAVE A PACK THAT WOULD HAVE ABOUT MAYBE 100 OR SO RARE EARTH MAGNETS FOR LIKE $1.04 IN THE LITTLE GENERIC VERSION OF THE "MEGAMAGZ" mmmbbuahhahahahahhahahaa
Oct 29, 2007. 3:21 AMNoodle93 says:
I have a better idea which involves the 'Caps Lock' key. But on topic: Magnets are awesome, and there's lots of instructables that use them.
Mar 20, 2010. 5:53 AMKred14 says:
 lol
Jan 31, 2010. 12:39 PMmomento mori says:
this was hella helpful.
many thanks. :)
Apr 21, 2009. 4:53 PMElQuinntero says:
would magnetix brand magnets work as good?
May 27, 2007. 8:20 PMgirrrrrrr2 says:
nice job...i just cut my hand open...big time!!!
May 29, 2007. 3:03 PMBongmaster says:
how in the name of great buggery did u manage that?
Jun 3, 2007. 7:20 PMgirrrrrrr2 says:
...metal shears...cutting the plastic in my hand...being stupid... does that help...
Jun 3, 2007. 7:55 PMBongmaster says:
clever trevor :P well its a learning curve :)
Jun 3, 2007. 11:03 PMgirrrrrrr2 says:
...my names not trevor... its girrrrrrr2... the cut/scar is going to be a curve(really)...lol
Jan 26, 2007. 9:12 AMdoobuzz says:
Try dismantling old hard drives, you know like the 1 GB ones you can pick up for nothing at the dump in old computers. My friend and i have been getting some really big (and powerful!) ones for nothing at all. This one picked up a chair in our science lab!
Nov 4, 2006. 9:34 PMstranoster says:
Try www.thinkgeek.com they are a reliable source of rare earth magnets
Oct 25, 2006. 3:17 PMRobotic_mage says:
trebuchet03; Sorry I mistyped(misspoke) 1/8" Dia x 1/16th" Thick NdFeB Disc Magnet, Grade N40, Ni Plated with Matte finish, Axially Magnetized (the top & bottom flat faces are the north & south poles). Click on image for larger picture. 1/8" Dia. x 1/16" thick Disc Pack of 50: $10.00 www.unitednuclear.com Left hand column, toward the bottom are the magnets.
Sep 12, 2006. 10:07 AMPetervG says:
Lot's of dollar stores sell these kits to, i'll buy a kit next time I go and post back if they are or not rare earth magnets.
Sep 15, 2006. 9:27 AMsockmaster says:
These are the kind of magnetic link toys I've seen at my local dollar store. Each set gives you 22 1/4" diameter by 1/16" thickness NdFeB magnets. This comes out to less than 5 cents per magnet and you get a bunch of free ball bearings too :)
Sep 30, 2006. 11:54 PMFrenchCrawler says:
I just refound your instuctable and was reading it: http://www.instructables.com/id/EKXVKRFW8JEP286SSU/
I want to try it out but lack the surface to do so.... maybe if I take the metal casing off one of the old computers, cut it flat and hang it on my door... Then I could have a welcome (or what ever I want) sign.
Sep 12, 2006. 1:42 PMzachninme says:
I think it is easier just to get them from a supplyer. After all, if you get those from a store they CANT be cheaper than just the magnets. And if you buy the magnets, you can pick size and grade (no less than N45 for me for a small magnet like that!)
Sep 13, 2006. 3:10 AMwestfw says:
6mm*1.5mm at less than $0.05 each:
http://www.kjmagnetics.com/proddetail.asp?prod=ZD1
(and a neat and reasonably priced magnetic levitation gadget... Works, too.)
smaller: 2mm*assorted for $0.03 each, 3mm*assorted for as low as 0.045 each:
http://www.engconcepts.net/List_Of_Disc_Magnets.asp
(lots of sizes of rectangular magnets; a regular supplier of the nuts who build
their own brushless motors for model planes.)
Sep 19, 2006. 5:46 AMwestfw says:
Also
http://www.extremeglow.com/Merchant4/merchant.mvc?Screen=PROD&Product_Code=MAGNETS
Rather larger magnets (10mm*2mm?), probably weaker.
Sep 12, 2006. 4:15 PMPetervG says:
Sure it might seem crazy and impossable but from a little LED flashlight I found out that LED works better than fine and is crazy look, it light up my rwhole room at night. And for only a dollar... Which reminds me, somone answer my question.
http://www.instructables.com/id/EO9HCP81HEERIE2N56/
Sep 18, 2006. 8:41 PMRobotic_mage says:
Go check out 'www.unitednuclear.com' you can get 50 magnets for a couple bucks.
Sep 12, 2006. 1:02 AMoskay says:
You can also extract the magnets by dissolving away the plastic. The advantage of that method is that it gets them out all at once, and the disadvantage is that you have to clean them after extraction. I wrote an article about that in July, linking to the exact same set that you show here. The article is at
http://www.evilmadscientist.com/article.php/MagnetExtraction
Sep 12, 2006. 11:26 AMoskay says:
Neodymium magnets will never regain their strength after being heated, so if you're willing to sacrifice them (and at this price, who isn't?), you could build the curie engine.
So I hear, neodymium magnets release toxic fumes when you burn them, so you'll have to be a little bit careful with your heat source. See
http://www.kjmagnetics.com/safety.asp
Sep 17, 2006. 11:28 AMspinach_dip says:
1946-1963 Canadian nickels, though they are easy to sort via a magnet.
Sep 12, 2006. 1:54 PMAlexTheGreat says:
I used some some neodnium magnets to hold something while i was weldig, now the magnets don't have any magneticity at all
Sep 13, 2006. 3:17 AMwestfw says:
By the way, this sort of toy with the easily removable magnets is the sort that was recalled due to possibly fatal accidents. Apparently eating one magnet is no particular problem, but if you happen to eat TWO, they can attract each other and "staple" your internal organs together, eventually causing things to tear or burst.
http://www.cpsc.gov/cpscpub/prerel/prhtml06/06127.html
http://www.google.com/search?q=magnetix+recall
(peronally, I think the CPSC is way out of control, but you still might think twice about strong magnet toys in families with small children...)
Sep 12, 2006. 9:16 AMhugedom says:
I don't know, some online stores/ebay are selling rare earth magnets for about that much anyways and you get to pick the sizes you want without the trouble. I can see if you got the toy set for ~$5, THEN it may be a "cheaper" source.
Sep 12, 2006. 8:37 AMNeodudeman says:
oh hey, i didnt know those were rare earths! well crap, i'm gonna get some for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
