Sous-vide Arduino Shield
 by sourjuice87
Featured
*NOTE* THIS PROJECT IS DONE BY A GROUP OF STUDENTS FROM SINGAPORE POLYTECHNIC
Sous-vide (/suːˈviːd/; French for "under vacuum")[1] is a method of cooking food sealed in airtight plastic bags in a water bath for a long time—72 hours in some cases—at an accurately determined temperature much lower than normally used for cooking, typically around 60 °C (140 °F). The intention is to cook the item evenly, not overcook the outside while still keeping the inside at the same 'doneness' and to keep the food juicier.
Items needed:
Arduino Uno x 1
2x16 LCD x 1
RGB x 1
LM35 Temperature Sensor x 1
Sparkfun Solid State Relay (SSR) Control x 1
1K ohm Resistors x 6
Push Buttons x 3
Vacuum Pump x 1
Electrical Heating Appliance x 1
AC Face Plate x 1
AC Plug x 1
Skills Needed:
Soldering skill
Basic electrical engineering skill
Overview:
DIY Sousvide Arduino Shield
AC Power Control
Code for Arduino
Experiment on Sousvide  Arduino Shield
Step 1:
Solder the following components into an Arduino Sousvide Shield as shown:
2x16 LCD x 1
RGB x 1
Push Buttons x 3
Purpose of the components:
Arduino Uno - Prototyping platform for testing
LCD - Display results (eg. temperature)
RGB - Visual signal
LM35 Temperature Sensor - Detect temperature
SSR - Electronic switching device in which a small control signal controls a larger load current or voltage
Push Buttons - Setting
beverageexpert says: Sep 3, 2012. 9:14 PM
I would like to use a dallas one wire ds18b20 and I am getting errors about unit8_t conversion to float
any suggestions to adapt your code to use the dallas one wire
teknohawk says: Aug 3, 2012. 7:09 PM
nice! but i don't quite understand, what does it do?
Orngrimm in reply to teknohawkAug 4, 2012. 1:22 PM
http://www.instructables.com/id/Beef-Ribs-Cooked-En-Sous-Vide-135-F-for-48-Hours/
It is to control the heat of the meat and if needed to readjust.
Computothought in reply to teknohawkAug 3, 2012. 7:20 PM
Keeps temperature constant for the cooling liquid. Cooking robot if you will.
Computothought says: Aug 3, 2012. 7:21 PM
Interesting wiring arrangement.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
