Step 11Variations on a theme
Jump rings, in particular, can be knit together in all sorts of ways. One of my favorites is Jens Pins Linkage (JPL3), where each ring added passes through two others to form a sort of spiral. When I am working those, I typically do not solder them, merely bend them into the proper configuration. I would also note that things like JPL3 are very sensitive to aspect ratio--the gauge of the wire related to the internal radius of the ring. Doing that wrong can lead to ugliness. If you want more information on that type of chain making, called maille, see M.A.I.L. The difficulty with soldering those types of links is that there is a high probability of soldering one link to another link unless you are very, very good or very, very lucky. I am neither. Also, the techniques for soldering chains can be used for normal chains as well. I have shown some variations, the one we just did is far left, followed by a variation with 12 ga small links that are left round, followed by a 14 ga JPL3, followed by a simple chain.
Add Comment
