Space Efficient Gardening Rack
13,337
487
5
Posted
Introduction: Space Efficient Gardening Rack
Have you got a small balcony and you can't garden there?
Have you got backache and you can't bend?
With our system all your gardening problems are solved.
This system makes it possible to save space on your balcony
and it can als adjust to different heights.
the advantages on a row
- makes it easy to garden on a comfortable height
ergonomic fold (user should not bend, just simple slide forward and backward)
- doesn't takes much place when it's in the vertical position (so when you're not gardening)
- you only need a few tools (only a drill, saw, meter and pencil)
- you don't need much materials and they are easy to find
- doesn't damage the balcony
- easy to attach and remove
- you can easyily customize this design for balcony's with different heights, by choosing other dimensions
Step 1: What You Need
MATERIALS:
- (1x) Plank
- (1x) Axl
- (1x) Beam
- (16x) L-profile
- (±30x) Screws
- (6x) Straps
- (3x) Pots
- (6x) Bolt Nut
TOOLS:
- Saw
- Drill
- Pencil
- Meter
Step 2: Measure & Saw the Frame
Measure the shelf and saw the four pieces for the frame.
Be sure to use the correct measures of your railing or the place where you are going to install the system.
You can choose the dimensions of your system  as you prefer.
Surely, try not to cut yourself.
Step 3: Drill
Drill the holes for the axl and for the bolts.
Remember for this system you always need one axl but the number of pots can be changed.
Step 4: Assemble the Frame
Screw the L- profiles to the planks.
Be sure to make it stable.
You can do it!
Step 5: Insert the Bolts
Now the frame is almost done, you only have to insert the bolts in the holes you made before.
Tighten them good to the plank using the nuts.
Congratulations your frame is done.
Step 6: Drill the Pots and Assemble Them
You almost finished the gardening rack system.
Now you have to drill holes in both sides of the pots, now slide them over the bolts on the rack
Be sure the bolt is long enough!
TIP: You can also look for other things to use to plant flowers/herbs/vegetables in, for example planting bags
Step 7: Measure & Saw the Rails
Now you have to make the piece which is going to be attached to the railing.
Measure and saw it in four different pieces.
Step 8: Assemble the Rails
Attach the pieces together, use screws for this.
Remember, you need two of those rails!
Those rails were the last two pieces, your system is done!!
Step 9: Step 9: Secured to the Railing
Finally, you only have to attach the system to the railing.
Don't forget to plant plants, vegetables or herbes! That's why we build the system isn't it?!
Easy right?
Enjoy it!
  • Woo ! I got one but ...-kokpat
    kokpat made it!
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
4 Comments
Brilliant! Thanks for posting such a thorough and cool Instructable. Your design complements the rest of your building complex too. Nice clean lines and the natural wood blends in with the environment without sticking out like a pink flamingo. Very cleverrrrrrrrrrrrrrr!
For the pots you can use the plastic rain gutters with end caps on both sides. Keeps them rigid in an extended length.
First Instructable I cast a vote on. Good work.
Thanks for the tip! It's a good idea to use the rain glutters if you don't want to spend money on flowerpots.
