Introduction: Space Helmet - LittleBits
Picture of Space Helmet - LittleBits
You can turn a motorcycle helmet into a space helmet with Littlebits.
Materials
Motorcycle Helmet
Coraplast or cardboard
Bits
2 power supplies
1 bright LED
1 microphone
1 speaker
2 wires
Tools
hot glue gun
tape
utility knife
Step 1: Mouth Cover
Picture of Mouth Cover
Cut out a shape like the one above. Practice with a cardboard or paper template first to get the right shape.
Then do the final plastic part from coraplast.  The hole in the middle is the same diameter as the speaker.
Then tape or hot glue it into shape.
Step 2: Install Bits
Picture of Install Bits
The wires, power supply, battery, microphone, speaker go into the mouth cover as shown. You can tape them in with 2 sided tape or glue them very lightly! (Not too much glue)
Step 3:
Picture of
Every helmet has a space between the outer shell and the soft inside. This is the place to slide the mouth cover. You will have to trim and adjust it to fit your helmet and face.
Important: the microphone should be very close to your mouth, this will make the cool distorted "Houston...we have a problem.." sound
Step 4: Mount the Light on Top
Picture of Mount the Light on Top
The last step is to mount the LED on the top for a light.
Your done...time to take a trip to space.
About This Instructable
1,656views
5favorites
License:
More by maxnoble440:Fruit Peel RGB LED Driver! Space Helmet - LittleBitsCrayon Lathe LittleBits
Add instructable to:
