Step 10Cast Pieces
Mix the glow in the dark pigment into the resin before catalyzing, or mix it into half before mixing the two parts. Because it's a powder it doesn't disolve in like a dye would, and you need to keep mixing it while you cast to keep it from settling.
Pour a bit into each mold, then use a pin or toothpick to draw the resin into the smaller detail areas. Fill it slowly the rest of the way to prevent air bubbles from getting trapped.
I pulled my pieces before they were completely hardened, this seemed to be easier on the molds. Coax the mold through the holes in your part with a toothpick to reduce mold stress.
Add Comment
