Step 11Finish Your Pieces
You'll probably need to do some sanding to them in the best shape - I use a dremel with a sanding drum for most of it, and needle files to fill in the details. It takes a while, but it's worth it.
Drill a hole straight down the center of each piece. Using a 1/16" bit will give you hole large enough for wire but thin enough to be subtle. Do this slowly and carefully and use safety glasses - hot plastic will fly at your face.
Add Comment
