Step 12Lamp Base
Attach loops made from head pins to the two rows of holes for the top piece. Put a pin through the hole, bend it over, cut it about 3/8 inch, then use the round nose pliers to roll the wire into a loop. This is where the stands of invaders will hang.
This is easiest to do now. Glue up the inner frame with the acrylic cement and let it dry completely. The pictures below show the steps, just make sure to glue up either stacks of 9 pieces and accept a small gap, or stacks of 10 and sand the pieces down to fit. Glue everything into a ring before wiring.
lampparts.dxf269 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
