3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Space Invaders Chandelier With Glow In The Dark Action
Step 14Glue on the Face Plate and Wire the Switch
You need to align the inner ring (that we've been wiring) to the face plate of the lamp. Make sure the hole for the switch is where you want it. Clamp things together as best you can and run some acrylic cement around on the inside of the lamp. Leave this to set up well before working on it anymore.
Screw (or attach) your switch to the lamp. The positive leads will connect to the switch (to the negative side, if your switch is labeled.) Shrink tube over the wire most of the way there. Cut a piece of the larger shrink tubing and slide it on. Then put the wire through the switch prong, twist it back on itself and solder. Slide the large shrink tubing down over this connection and shrink it.
Attach a wire to the other side of the switch the same way, and shrink it for about 5 or 6 inches. Slide on a piece of the big shrink tubing. Then twist that wire together with the positive lead from the battery snap. Solder them, then fold the solder section back toward the switch and shrink over it. This is to prevent the connection from coming undone if someone pulls on the battery. Do the same thing to connect the negatives from the LEDs to the negative on the battery and your wiring is done. Pop in a battery to check things before you close it up for good.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
203
Author:technoplastique(Technoplastique Blog!)
I'm making something new for every week of 2012. Check my blog to see what I'm working on!
