Step 16Chain Up the Cast Pieces
Slide each one (except the bottom row) onto craft wire. Make a loop on the wire, slide the piece down, then cut it off (around 3/8") and make a loop at that end. Using round nose pliers makes this easy. This turns each into a charm. Use a head pin for the bottom charm so there's no loop at the bottom.
Use jump rings to link them into vertical rows. I used one position of each alien for one row of charms, the other position for the row of charms on the other side of the LEDs. I used some short lengths of chain at the top to make sure the strands were all aligned. The orientation of the loops on each piece determines the direction it hangs. You can use a bit of super glue at the place where the loops and piece meet to keep things aligned.
Get them in some good sunlight for a while for the best glow.
Add Comment
