3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Space Invaders Chandelier With Glow In The Dark Action
Step 5Make a Really Complicated Shape
  • last photo ←
This is the process for making the most complicated object, one of the small aliens at the top. It has a lot of holes and narrow connecting pieces. If you can get through making this you should be able to extrapolate the process into any of the other objects. I split this into two steps because there were so many images.
Start out by extruding a shape that is the full block of the object. Extruding in one block increments is important for editing later. Extrude the beginning cube to the right until it is four blocks wide, then to the left until it is a total of eight segments wide. (I do this to keep the object reasonably well centered in the work area.) Extrude all of that up one block. Then extrude up the center 6, then 4, then 2 blocks. Extrude the entire width down three more rows, the entire height should be 8 blocks.
At the bottom of the gridded screen click on the triangle icon to switch into face select mode. Select the square of the right 'eye' of the alien (apple key + click or right click). Push the 'x' key to delete it, then click on 'Faces' to only delete the face. Because the object is three dimensional you have to repeat that in the same place to remove the back face's 'eye' as well. Once you've done that you should have a hole through the object. Do this same thing for the other eye.
Select the lower three block rows with the border select, then click on 'subdivide' in the mesh tools category at the bottom of the screen. Click it again. There should now be 16 small squares where there used to be one big square.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
203
Author:technoplastique(Technoplastique Blog!)
I'm making something new for every week of 2012. Check my blog to see what I'm working on!
