Step 7Complicated Shape (Part 3)
Use border select to select any two points (from the front - that's 4 total) and then use the 'f' key to make a face. Deselect those (a), then do it again everywhere you need a face, with the exception of the corners (as labeled in one of the images below.) There are probably faster ways to do this, but this method if very reliable for making a printable object.
After the easy ones are done, rotate the object (hold down option while you click and drag) to see a corner spot. Select three points, then use 'f' to make a face. You'll need 5 faces for each corner.
When you think you're done, hit the space bar, then go to select > non-manifold. Anything it highlights will be a place where you missed something. Keep working on it until the non-manifold doesn't highlight anything.
Add Comment
