3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Space Invaders Chandelier With Glow In The Dark Action
Step 9Make Molds
Make Molds
You'll to clean up your new pieces a bit (a straight pin works great), as they usually have a bit of dust and grunge on them. Once that's done, make your mold by measuring out the putty in two equal pieces, mushing it together until it's one color (as quickly as possible), then getting to work on your mold.
First, smoosh as much of it into the holes as you can. For real. The denser that silicone is the better. Then wrap the rest of the silicone up around the sides, and push it down onto a flat surface so it will be level when you cast into it. Let it set up all the way - leave it for at least half an hour.
I chose the silicone I recommended because it's tough and has an oily surface. You'll need to carefully work your piece out of the silicone, push down on the silicone in the holes a bit to encourage it to slide out instead of tearing off inside the eyes. If it does tear off you can push a bit of 24 gauge wire through it and into the base so the mold will still work.
Make at least one of each piece, making a few with make things a lot easier.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
203
Author:technoplastique(Technoplastique Blog!)
I'm making something new for every week of 2012. Check my blog to see what I'm working on!
