Step 5Final assembly and testing
Set the thermostat for heat mode and increase the set temperature above the room temperature as shown. Make sure the relay closes and 110VAC appears at the outlet, or the lamp turns on. If it checks out, test it with a real space heater, and allow it to run at least half an hour on your bench. Turn it off and inspect for any overheated wires or hot components.
If everything checks out, congratulations! You now have a digitally programmable space heater!
I gave you a 5 Best Instructable Ever.
Just wondering though, if you (mightyohm) is the author, why does it list P914 as the author?
Thank you for the great instructable, and your help with it.
Have you tried this in "Cooling" Mode, and plug in a portable air conditioner instead? I'm sure it is possible, just not sure how the wiring currently controls it all. Does it bypass the Controllers cooling portion, or is it one in the same?
Please advise, as I have a real need for a portable air conditioning controller. Your work is perfect!!
Thanks again!
Good Luck!
A++ Idea
