Space Ship From Cardboard and Foam Camping Mats
17,905
95
28
Published
Introduction: Space Ship From Cardboard and Foam Camping Mats
About: I love to create. I started as a professional photographer and my interests have led to sculpture.
please read through the whole instructable before you begin and if you want I will sell full size cutouts of the superstructure just contact me through this website.  I had fun designing and building it, I hope you will too. Also keep in mind this particular ship is 3 feet long and 3 feet wide, its biggg!
Step 1: Making the Seat Sized for a Drawing Doll
O.k. you will need an electric knife(to cut the foam camping mat clean), a razor blade or utility knife, scissors copius amounts of hot glue, pens a cutting mat helps and of course cardboard, and a hot glue gun. What I don't have on this site is all the measurements( I create as I go) but at the end of this instructable I will leave my blog address where you can contact me to get plans.
  The seat is just cardboard bent to conform to the doll, then witha hot glue gun I took round window draft stopper(available at home depot) and arranged it the way I liked as I glued it to the chair.Also you will need 3 foam camping mats(I got mine at canadian tire). Total project build was about 100 dollars over time.
Step 2: Doll in Chair
Here you can see the doll in the chair and the beginning of the dash which I made from uhm plastic.
Step 3: Making the Body of the Ship
In thjs step I have fitted the cockpit which is a folded piece of cardboard, the folds are the same width of the chair. Then I held the cockpit against the side of the ship to make a slightly curved cut matching the side of the body
Step 4: Cockpit in Place
This shows you the cutout for the chair and pilot, basically the width of the chair up to the point where his knees are bent.
Step 5: Full Body View
Step 6: Back of Body
this is the back. you cut the top velcroed piece to match the distance to the back of the chair, glue in place. The bottom piece can run the full lenght of the bottom, folded to hinge up and over the top. this is your battery compartment. Don't make these cutouts, I decided to go in a different direction.
Step 7: Side View of Body
guys, don't worry about the intake you see in the bottom of the bottom, again it wasn't inluded in the final model. In this picture you can see the front supports I put in to support the foam. In hindsight these pieces could have been solid instead of looking like a framework.
Step 8: Starting the Framework for the Engines
ow this is the part where you make sure everthing is at a 90 degree angle. Take your time and make sure everthing is glued tight.
Step 9: Front View Starboard Engine
another view of the engine. the back tubes are 3 inches in diameter and the front cone is pipe insulation from home depot.
Step 10: Both Engines
heres a view of the two engines. I have started adding strips to the side of the first engine. DON'T put strips all the way up yet, we are going to add some turbines and lighting.
Step 11: Mockup
Heres a simple mockup. I have added the cockpit which is simply three pieces glued together, again make sure you cut the bottom of the canopy to allow for the curvature of the body.
Step 12: Turbine Computer Fan
here you can see the silver painted computer fan glued to the superstructure. cut four wires long enough to travel to the back of the ship to power the fan and an led.
Step 13: Turbine
turbine is powered by a 6 volt battery bank in the back, just make sure you have 6 volts hooked up to it befor you turn it on or you'll blow the whole thing, which I did.
Step 14: Engine Mounting
In this step I have finished all the wiring, painted the back exhausts and front intake black and figurd out where I want them to sit on the body
Step 15: Engine and Cockpit Mounted
Here are the engines glued in place. The cockpit is mounted using a simple cardboard hinge also
Step 16: Starting the Wings and Gatlin Guns
Heres how the wing goes together. Notice the folded edge,this is how you mounts it to the ship, leave it unglued. You can see the gatlin guns at the top made from half inch dowels and a 2 inch cardboard tube. I carefully drilled out about 2 inches of each dowel for the barrels.
Step 17: Covering the Wing
simply glue the foam to the wing and cut the excess off with an electric knife for a nice finished edge
Step 18: Covering the Body and the Addition of Gun Housings
There is no real trick to applying the foam, put glue as much glue as you can and keep the foam taught as you go. The ship gets as fancy as you want it to.
Step 19: Back of Ship
This shot shows yu where I finally decided to attach the wings on the exhausts and a few fine details, you can add whatever you want
Step 20: Front Cowling
Heres a shot of the cowling detail
Step 21: All the Wings
Here I've added vertical wings, it looked a little unbalanced
Step 22: Burnig and Rivet Detail
O.k. this is where it gets fun, get a small butane torch and don't hod it too close. I like to move in a side to side motion. This is the aging process. I have also added vertical takeoff manifolds just in front of the wing, pure foam. The rivets are just dots of black marker.OPEN A WINDOW FOR VENTILATION!!!!!!
Step 23: Front View Ageing
Again just play with the torch to get it the way you want, you will be covering alot of it with paint.
Step 24: Start Painting
You can see I've spray painted the front of the turbines with a little silver paint. I brushed on silver paint on the exhausts and added some foam blocks to them. The rest of the ship is being painted with acrylic paint from the artstore.
Step 25: Checkerboard Stencil
In the next step you will see the checkerboard strip on the side of the turbines, I made the stencil with edging tape from the home depot and a utility knife
Step 26: Checkerboard
I put the stencil on the ship and painted the white squares, the black squares I painted in by hand
Step 27: The Dash
Here you can see the dash glowing via a 3.3 volt light light I glued in underneath the foam dash
Step 28: Installing Lights and Back Detail
There is a 24 volt system (altogether) powering all the lights and the simulator which yu will see after. I am a terrible electrician so I hope you guys can come up with something better. All of the lights are 3.3 volt run out to D-battery packs from The Source .Glue all the sockets in place and run your wires to the hidden switches(I put rocker switches under the foam at the back just in front of the velcro closure. For the exhoust caps I used clear plastic beer cups and painted the bottom of them blue, they sit in there perfect. You will also noticed more engines I added to the back as an afterthought all built from foam. They are also capped with beer cups.
Step 29: Building the Flight Simulator
Since your giant 3foot by 3foot space ship only weighs in at about 7 pounds we can build a flight simulator to fly it on
Step 30: Flying Th P-38 Thunderhawk
flying in my living room
Step 31: The Finished Product
This kind of gives you anidea of the finished product, picture plans will follow soon for the simulator
Step 32: The Red Dragon
This is the first ship I built. I used one of my sons old four wheel drive rc trucks to make the gatlin guns that really turn, unfortunately I didn't document this one, Sorry
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    28 Discussions
    Thank you very Much ! I have to get my butt back in gear posting some new stuff lol !
    I thought this was pretty cool. Then I saw the flight simulator and I thought it was fantastic! That next step takes this to a whole new level. Nice work.
    I am speechless! Amazing instructable and amazing work! Now all I got to do is show this to my star wars-crazed friend and find some camping mats!
    Thankyou very much, i am currently working on a website so i can show all of my work, it will be posted here in the next couple of months
    How much did this project cost? Do you think it would be cool to have a remotely controlled flying version or a model rocket version?
    what about rocket engines you hook it up for a rocket contrele also what the name of that trinagle thing that hovers might work uh
    sorry for the late reply. the whole project cost was around 60 dollars, for the electrical stuff. the rest was cheap, the camping mat foam came from canadian tire, 2 x 20$ and the rest was from the source. the model is approx. 3 feet by 3 feet and weighs about 10 pounds (batteries). little heavy for remote operation, but it would be very cool.
    wow i scrolled through the whole instructable to find the final project to realize what i thought was cgi on ur first page was ur actually product
    Very nice piece! but i would like more information about the  flight simulator, thanks in advance
     EXCELLENT.....brilliant well maintained 5/5 and far more!!!!
    Very cool!!
    I'd like to see an instructable on that flight mechanism.  If it does what I think it does, it would be great for greenscreening or "Drawless Animation" stuff.
     That is awesome in so many ways, you really need to make a video showing us the ship, and also of that funky flight mechanism at the end!
    O.k. I'll get a video made this weekend, gotta see if the format from my video camera is supported but thankyou very much
