3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spanner Wrench for a Watch Case
My watch has a screw- in back on the watch case. It is possible to order a universal spanner wrench for around $10 US. I wanted to make my own spanner wrench so I can replace the battery without needing to get to a store that can change it for me.
In the photo you can see the indents for the spanner wrench so it can unscrew the case back.
Step 1Use a mending plate
Use a mending plate
I used a 1/2 x 2 inch mending plate. These are available in any hardware store. Any thin piece of steel would work, too. (The photo is from Google Images.)
26 comments
Aug 14, 2010. 6:19 PMtassie2 says:
Maybe this is here on site, but.. A Vietnamese watch repairer outside the train station near my house did thousands of batteries on watches. For commuters in a hurry. His tool of choice? A metal vernier caliper measuring tool. A lot of people here will have one in their workshops! Multi adjustable of course.. Unless a watch was xxx tight he could unscrew and replace a battery in about 45 seconds! Always puffing air into back of case first to clear any dust. The good quaility eg Mitutoyo verniers with a screw lock are ideal You can lock them in place. Load on them is negligable in the scheme of things. He always sat his watches on a sandbag/ soft support. For xxx heavy watchbacks he had a real watch undoer as a backup. Seldom he used it! Like I say he did thousands.. Pic uploader not working for me... will try a pic send for you guys later!
Mar 4, 2012. 6:28 AMconpeters says:
Thank you for this brilliant tip.
Con Peters, Netherlands.
Aug 14, 2010. 6:26 PMtassie2 says:
hi pic enclosed re vernier watch tool. tassie 2 australia have a nice day
Feb 28, 2012. 2:59 AMbilltr96sn says:
You can also use a pair of scissors. I take no responsibility for you cutting you fingers off though.
One thing I would like to add though, do not overtighten the back of your watch when you replace it.
Jul 31, 2010. 9:27 AMstienut says:
Great ible. Just made one, took about 45 minutes. I used a dremel with a cut-off wheel, can't imagine hand filing it.
Oct 14, 2009. 5:34 PMSolderguy says:
I think I love you. I have a mechanical watch that got waterlogged, andI wasn't able to open it. I'll try your instructable and post the results.
Oct 14, 2009. 10:58 PMSolderguy says:
The home-made spanner wrench I made worked flawlessly. I first made onefrom a broken hack saw blade, but it was too flimsy, so I got a steelstrip and used a dremel to cut a groove in. I had to put the spannerwrench in a vice and twist the watch with both my hands because it wasso stuck in there. I'm happy because the inside isn't rusted to nothing(all the gears are brass), so all I have to do is free a few gears fromthe grip of the rust and it should work. Thank you so much. 5/5
Oct 14, 2009. 3:00 PMBenhamCollectibles says:
This is a great idea. I signed up for an account just to get back onthis posting and give props to whoever came up with the idea. My wifeand I have matching Fossil watches and I couldn't figure out a way toget that back off of it when the battery died. Great Thinking!!
Oct 12, 2009. 4:00 PMklee27x says:
You can cut a nice spanner wrench out of a hack saw blade. They're high carbon steel, and the result is very nice - flat and shiny. If I still had mine, I'd post a pic.
Oct 6, 2009. 5:11 AMrimar2000 says:
Phil, I looked "astuto" in Google translator, and found the following: crafty nombre: 1. colic adjetivo: 1. cannie 2. smart 3. clever 4. sharp 5. politic 6. knowing 7. wide 8. worldly-wise 9. pawky 10. shifty 11. sleeky 12. slick 13. devious 14. guileful 15. canny 16. tricky 17. leery 18. sly 19. foxy 20. wily 21. artful 22. crafty 23. cunning 24. dodgy 25. astute 26. deep I think CLEVER is the word fro you!
Oct 6, 2009. 6:10 AMrimar2000 says:
Some wars were caused by inexperienced translators ...!
Oct 6, 2009. 11:11 AMVagsmaCutter says:
I'm a machinist by trade, but I guess that makes me a bit heavy handed for watch repair (I always end up scratching something, always). Making tools is one of my favorite things to do as well, so I may end up doing this if my usual way fails (take a large rubber stopper and press it to the back and turn). Making tools is so gratifying, I bet it felt good when it first turned.
Oct 5, 2009. 1:54 PMKoosie says:
Nice, a simple, quick solution for time-consuming problem :)
Oct 5, 2009. 12:28 PMjcard21 says:
I let my watch guy replace my SEIKO quartz watch batteries, because he will inspect/replace the rubber gasket, plus add silicon to lubricate it, so when the back is re-installed, it will not "bind" and tear the gasket. He doesn't charge me for little things. Example: My 1960 LONGINES Automatic (NOT quartz/no battery!) stopped a week or two after being serviced by him. I brought it back. He immediately opened the back, and there must have been a speck of dirt lodged inside, because he just touched something inside, and the watch immediately started running again, and has been running ever since. (He did say it could happen again.)
Oct 5, 2009. 10:06 AMTabLeft says:
Cool, I always just use needle nose pliers though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
