Introduction: Sparkfun Stock Checker
Picture of Sparkfun Stock Checker
This is a simple instructable in how to make a device that checks the stock of various products at Sparkfun.com. it is very easy to modify and i hope someone does!
Step 1:
Picture of
you will need all of these parts:
-Raspberry Pi with all the fixins (sd card, keyboard, mouse, ethernet/wifi, preferably a monitor)
-and then one of these two: (the pi lcd plate is easier for beginners):
---raspberry pi lcd plate (http://www.adafruit.com/products/1109)
---or a lcd shield (http://www.adafruit.com/products/772) and a logic level converter (3.3v to 5v, your choice.)
install Raspbian on your pi if you dont have it already. there are many great instructables for doing that.
Set up I2C as described here: (don't do any of the libraries yet) http://learn.adafruit.com/adafruit-16x2-character-lcd-plus-keypad-for-raspberry-pi/usage
then download this whole gist from github: https://gist.github.com/red-green/6118462/download (sorry the name is messed up)
Step 2:
Once you have the code, using it is very simple. extract everything to your home folder and open a terminal. then type "sudo python sfestock.py".
to edit the list of products it displays, just type nano sfestock.py and use your arrow keys to navigate to the line that says
productid = [11546,11868,11589,11021,11286,9716,11215,11712,8938,709,569,8653]
You can edit those numbers to any IDs you want. seperate each one with a comma.
if you know a bit about python programming, you can change the api it uses. minidom is a great XML parser and the CSV library also is very useful.
ShawnHymel (author)2013-09-21
Nicely done! This would be useful for keeping an eye on some popular items, like that oh-so-elusive Raspberry Pi Model B :)
red_green (author)ShawnHymel2013-09-26
That the reason i made it in the first place (although it requires a pi)
About This Instructable
1,736views
12favorites
License:
More by red_green:Arduino Mobile OSSparkfun Stock CheckerBoe Bot/Arduino line following robot
Add instructable to:
