Introduction: Speaker- BOOM BOOM
Materials needed:
Enamel coated Wire
Magnet
Stereo chord
Stereo
Resonator
Meter Stick
Tape
First: Measure 142cm of enamel coated wire.
Step 1:
Roll the enamel coated wire around a cylinder object in order to create a coil. You wrap the wire into a coil so the electrons can shoot across because they have to shoot diagonal . The more loops you have in the coil, the better the sound will be, so make the coil have a diameter of around 5 cm.
Step 2:
Pull the wire off the cylinder and make sure it remains in a coil.
Step 3:
What the coil should look like:
Step 4:
Take a piece of tape and tape the coil/wire to your resonator..
Step 5:
Take a razor and strip the coating at each end of the wire in order for the wire to conduct.
Step 6:
Plug each end of the wire that have been stripped into the speaker cables/cords.
Step 7:
What it should look like:
Step 8:
Position magnet in order to set the box with coil directly above/on top of the magnet.
Step 9:
Not a very good photo of how the alignment should look but the center of the magnet should make some contact with the coil, almost perfectly aligning.
Step 10:
Now listen to the stereo, gradually increasing the volume until it cuts out!
