Speaker Case
4,722
6
9
Posted
Introduction: Speaker Case
You have a speaker out of an broken toy or out off a computer and you want to make a cool case for it? Here is an easy way to make a case out of a 6V lantern battery.
Step 1: What You Need
You Will Need
1) 6 volt lantern battery
2) Speaker
3) Knife
4) Soldering Iron
5) Solder
6) Glue
Step 2: Open It Up
To pry open the 6 volt lantern battery use a knife to scour along the seal and they slip it under the plastic and leaver off the lid from the casing. Once you have the lid removed you will find 4 1.5 volt cells that are wired in series. Remove this by pulling it out off the casing.
Step 3: Clean It Out
In side the casing there are 4 dividers used to keep the cells in place and to stop them from shorting. Using a sharp knife or a Xacto knife cut all of the dividers out of the casing.
Step 4: Make a Hole in It
To achieve the right size hole for my speaker i measured the radius of the speaker because that was the easiest way to find the center. Subtract a few millimetres so there will be some case left to attach the speaker to.
With a ruler and a compass place the pointed end of the compass on the zero mark of the ruler and the pencil tip on the measurement. On the bottom of the casing there is a mark left from a process called injection blow moulding when it was made in a factory, this will be in the center.
Place the compass on the mark and make your circle. Cut it out with the knife. If the edges are not smooth
use a file to smooth them off. Remember wear glasses as you don't want to get a file of plastic in your eye.
Step 5: Glue in the Speaker
Glue around the outside of the speaker and sit one of the cells on the back of the speaker of it to apply pressure. Stopping the speaker from coming detached from the casing while the glue dries.
Solder each wire from the speaker to one of the terminals on the back of the lid.
Snap the lid back on and you have finished. To use the speaker connect the corrected cables to the terminals on the out side of the lid.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
  • Sew Warm Contest 2018
9 Comments
I HAVE THE SAME KNIFE :)) did you get a black one with yours?
is that a leatherman juice?
Its a Gerber Clutch. Decent Instructible, i think it would be better if you shortened the case though.
sry hard to tell
What advantage do you gain by mounting the speaker in this case? L
The advantage obtained by mounting the speaker in this case is the speaker is more protected and you now have the speaker projecting sound at 90 degrees, not at 180 degrees as if it was laying on its back.
Sorry, I meant to be specific about the acoustics of the casing (but it was late I and was tired) - i.e. does this sound different, perhaps at lower frequencies? L
the bigger the enclosure, the lower the frequency produced
if you're interested in speakers, get Bass Box Pro 6
http://thepiratebay.org/torrent/3229123/BassBox_Pro_v6.0.18_(speaker_enclosure_design_program)
