Step 4Intake Modification
Cut a very small (approx. 1/4" length) piece of the tubing that came with the Swiffer WetJet.
Cram the small tubing into the 1/4" tubing - it should be a perfect fit
Modify the hose clamp - bend off the little tabs on the inside of the ring. This will make the hose clamp able to close even tighter, without chewing up your tubing.
Apply the hose clamp to the tubing, directly over the piece of small tubing. Tighten this until there is only the tiniest hole in the tubing.
Push the assembly onto your pump's metal intake. It will stay on without any problems. If you are paranoid, you can add tape. I'm not.
Add Comment
