If you are concerned about keeping these healthy, know that I have done the math on carbohydrates, and following this recipe you are getting a slightly larger bar with the same (or slightly less) than you would get from a commercial cereal bar. Using all Splenda (no sugar) and a little less corn syrup, you will make a lower carb' treat.
Remove these ads by
Signing UpStep 1Go shopping, buy your supplies.
- 1 Box (about 7 cups) - Generic Strawberry Special K Cereal (pictured is "Strawberry Awake" from Wal-Mart)
- 1 Cup - Splenda Sweetener (see notes below) or Sugar
- 1/8 - 1/4 Cup - Powered Milk (gives it that breakfast cereal taste)
- 1 Cup - Light Corn Syrup (one jar is about 1 1/2 cups)
- 1 squeezable icing - Not at all healthy, but gives a nice appearance
- 1/4 - 1/2 Tablespoon - Artificial strawberry flavoring
- 1/2 bag - Dried cranberries
Now, I should explain a few things about ingredients ...
Corn syrup is liquefied sugar. It's loaded with carbohydrates. Following this recipe, you will make breakfast bars that are AS healthy as a name brand "Special K" bar (which is not healthy at all). You may modify this recipe, but the less syrup you use the less sweet your bars are. Also, the sticky consistency of the syrup makes these easy to press into bars. Using less syrup will give you crumbling bars. Some have suggested using honey ... which wouldn't taste well here. Also, if you go with honey, check the label. If you are buying the cheap stuff, the chances are it's mostly corn syrup anyway. The bottom line is: I would not suggest using less than 3/4 cup of corn syrup for this recipe.
Splenda is expensive, and may have health risks! You can really use Splenda as you would sugar, and in this recipe you will never taste the difference. In fact, you could cut back and use less than I did - because the cereal is all ready infused with a good deal of sugar right out of the box. But ... because of the cost and possible health risks, you may just want to use real sugar. If you are going to eat more than a few of these in one sitting, use sugar. For more information - see this WikiPedia page - http://en.wikipedia.org/wiki/Sucralose
Cranberries? Yes. Have you ever checked the ingredients on the name brand bars? They use strawberry flavored cranberries. Note that you will be more than doubling the amount that they put into the commercial bars - and these are very good for you.
Powered Milk? It's not really required. I would suggest only using a small amount, if at all. It's well worth it for that hint of a milky taste in the final product. Use too much, and your liquid process will turn into a meringue.
Artificial Flavoring This too can be skipped all together. It will run you about $3.00 for a small bottle. If you use it, use it VERY sparingly. The flavor comes loose when it hits the sugar. Do NOT use any more than 1/2 a Tablespoon. This was an experiment on my part, and I thought the final product was very tasty with the added flavoring.
Icing on a healthy bar? I know someone is going to hit me on this. It's pure sugar. If you don't want to use it, don't buy it. But your final product won't have that Martha Stewart appeal if you don't ice it.
http://reviews.ebay.com/Make-your-own-cereal-bars?ugid=10000000006954625
Just try not to buy stuff with too much sugar added. If you want, Adam's makes a good peanut butter that would probably work really well.
The other suggestion is to sprinkle a little stevia extract as a replacement for a couple tablespoons of sugar.
Basically all the products you listed were from the seemingly healthy food options offered at Walmart, no offense to anyone its just an observation based on the brand names. The better option would be to shop online for organic alternatives. They are usually priced fairly reasonable.
Think about it, where do you want to pay the price. You either pay a little more now, for a greater return - longer richer life - then pay slightly less and get only a temporal sensation from fast food.
And yes, they sweeten ant poison. Because ants preferred it two to one against vinegar flavored poisons. ;-)
In fact, if you have allergies that magically appear after it rains or in the Spring, find a LOCAL source of honey and/or bee pollen. Your body will start developing antibodies and readjust your histamine level.
Healthier to me would be; unrefined cane sugar, molasses, honey or stevia.
Adding nuts to the mix could also help and increases protein content.
Sure get's me hungry though... :)
Citing WikiPedia on the topic of "Sucralose" (sweetener used in Splenda) ...
Sucralose has been accepted by several national and international food safety regulatory bodies, including the U.S. Food and Drug Administration (FDA), Joint Food and Agriculture Organization/World Health Organization Expert Committee on Food Additives, The European Union's Scientific Committee on Food, Health Protection Branch of Health and Welfare Canada and Food Standards Australia-New Zealand (FSANZ). According to the Canadian Diabetes Association, one can consume 15 mg/kg/day of Sucralose "on a daily basis over a ... lifetime without any adverse effects".[13] For a 150 lb person, 15 mg/kg is about 1000 mg, equivalent to about 75 packets of Splenda or the sweetness of 612 gm or 2500 kcal of sugar.
... it's amazing what you learn in user based communities such as this one. :-) I will modify the recipe with some additional notes.
In addition, there is a lot of info on the "discussion" section on the Sucralose Wiki page. I can recommend to always dive into the discussion tab when trying to form an opinion as it shows many different views on the subject.
I'm not here to debate if we should use artificial sweeteners though...
I do feel there is no need to use these products in the first place.
I can definitely recommend Stevia, although the FDA doesn't...
You can read about it here:
http://www.naturalnews.com/022339.html
http://www.naturalnews.com/022234.html
(last page also has some disturbing info on sucralose)
Cheers,
