Speech Recognition With Arduino
212,527
280
116
Published
Introduction: Speech Recognition With Arduino
In this project I use BitVoicer’s speech recognition features (http://www.bitsophia.com/BitVoicer.aspx), one Arduino board and one electret microphone (https://www.sparkfun.com/products/9964) to control a few LEDs.
This project is similar to the one in my first post (https://www.instructables.com/id/Speech-Recognition-with-BitVoicer-and-Arduino/), but now I use audio streaming to send audio to BitVoicer.
The fritzing schematic I added to this instructable shows how I wired my Arduino board.
I’m also adding a few pictures and a YouTube video of the project running.
Unfortunately, the sketch I wrote for my first post is no longer supported by the new version of BitVoicer. Here is the new sketch:
#include <BitVoicer11.h>
//Instantiates the BitVoicerSerial class
BitVoicerSerial bvSerial = BitVoicerSerial();
//Stores true if the Audio Streaming Calibration tool
//is running
boolean sampleTest = false;
//Stores the data type retrieved by getData()
byte dataType = 0;
//Sets up the pins and default variables
int pinR = 3;
int pinY = 5;
int pinG = 6;
int lightLevel = 0;
void setup()
  //Sets the analog reference to external (AREF pin)
  //WARNING!!! If anything is conected to the AREF pin,
  //this function MUST be called first. Otherwise, it will
  //damage the board.
  bvSerial.setAnalogReference(BV_EXTERNAL);
  //Sets up the microcontroller to perform faster analog reads
  //on the specified pin
  bvSerial.setAudioInput(0);
  //Starts serial communication at 115200 bps
  Serial.begin(115200);
  //Sets up the pinModes
  pinMode(pinR, OUTPUT);
  pinMode(pinY, OUTPUT);
  pinMode(pinG, OUTPUT);
void loop()
  //Captures audio and sends it to BitVoicer if the Audio
  //Streaming Calibration Tool is running
  if (sampleTest == true)
    //The value passed to the function is the time
    //(in microseconds) that the function has to wait before
    //performing the reading. It is used to achieve about
    //8000 readings per second.
    bvSerial.processAudio(46);
  //Captures audio and sends it to BitVoicer if the Speech
  //Recognition Engine is running
  if (bvSerial.engineRunning)
//This function runs every time serial data is available
//in the serial buffer after a loop
void serialEvent()
  //Reads the serial buffer and stores the received data type
  dataType = bvSerial.getData();
  //Changes the value of sampleTest if the received data was
  //the start/stop sampling command
  if (dataType == BV_COMMAND)
      sampleTest = bvSerial.cmdData;
  //Signals BitVoicer's Speech Recognition Engine to start
  //listening to audio streams after the engineRunning status
  //was received
  if (dataType == BV_STATUS && bvSerial.engineRunning == true)
    bvSerial.startStopListening();
  //Checks if the data type is the same as the one in the
  //Voice Schema
  if (dataType == BV_STR)
    setLEDs();
//Performs the LED changes according to the value in
//bvSerial.strData
void setLEDs()
  if (bvSerial.strData == "wake")
    digitalWrite(pinR, LOW);
    digitalWrite(pinY, LOW);
    digitalWrite(pinG, LOW);
    digitalWrite(pinR, HIGH);
    digitalWrite(pinY, HIGH);
    digitalWrite(pinG, HIGH);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "sleep")
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "RH")
    lightLevel = 255;
  else if (bvSerial.strData == "RL")
    lightLevel = 0;
  else if (bvSerial.strData == "YH")
    lightLevel = 255;
  else if (bvSerial.strData == "YL")
    lightLevel = 0;
  else if (bvSerial.strData == "GH")
    lightLevel = 255;
  else if (bvSerial.strData == "GL")
    lightLevel = 0;
  else if (bvSerial.strData == "ALLON")
    lightLevel = 255;
  else if (bvSerial.strData == "ALLOFF")
    lightLevel = 0;
  else if (bvSerial.strData == "brighter")
    if (lightLevel < 255)
      lightLevel += 85;
      analogWrite(pinR, lightLevel);
      analogWrite(pinY, lightLevel);
      analogWrite(pinG, lightLevel);
  else if (bvSerial.strData == "darker")
    if (lightLevel > 0)
      lightLevel -= 85;
  else
    bvSerial.sendToBV("ERROR:" + bvSerial.strData);
The BitVoicer Voice Schema I used can be downloaded from: http://www.justbuss.xpg.com.br/BitVoicerTest2.zip (you need to have BitVoicer installed to be able open it).
Now I want to control a few things (lights and celling fan) at home. Suggestions are very welcome.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    Can Bitvoicer be used with an ATTiny85 to program the commands and remove the dependency of having it work with the laptop?
    116 Comments
    I have been getting an error in the code...compilation terminated. exit status 1 Error compiling for board Arduino/Genuino Uno
    both the arduino uno and correct com port are chosen
    I had same problem. I solved it by including library used in the code. Hope it works for u
    Go to your installation folder of BitVoice, copy the contents of 'library', paste them into 'libraries' in the arduino installation folder
    Try googling ur error or post in arduino forum.
    I need help with the communication settings for my microphone. I am using the max4466 electret microphone but from the bitvoicerserver manual it says the serial number must be 20 characters. How did you guys find the serial number for your microphone?
    Is there a way to edit what the arduino accepts as audio inputs?
    You can control home appliance with a relay module.
    I have made an instructable tutorial on Home Automation, just check out if you need help .
    Santamanyu
    I have found a comment you made in 2013 - about a 100 years ago, or it seems that long. I need exactly what you wrote about. Schematics and software for a miniature device that can hear an audio codeword amongst daily normal noise and when it hears that closes a relay. Any contribution available from you as to how and what can do this?
    Harold Tracey - dvrdigital@gmail.com
    Can this thing be wireless. I mean connected to the cloud and not to the computer
    Surely you can. Nothing is impossible. but you will need more modules to fill the gap like wifi shield, etc as per ur requirement. But if you want to connect to the cloud also you will need to process the voice somewhere to make it detect as a command. So think about it
    Can i use bitvoicer software for speech recognition without connecting it to pc?
    Then you would need to use raspberry pi instead of a pc. Arduino itself isnt capable of doing anykind of voice or image processing itself.
    Hello, where can I get the arduino library
    hello there how you doing ? it is nice what you have posted. I was working on speech recognition elevator using arduino and speech recognition module v3, how can i interface these things ? I have only two weeks for defence so pleas help me ?
    can i use android app like voicecontrolaurdino for the same code ?
    I know that BitVoicer does not fit compatibly with Mac, but is there any other similar software like BitVoicer which is compatible on Mac?
    can i use normal condenser microphone for it? and how?
    that is what I am trying...but I am having coding issues
    I was wondering if you can make this with this mic:
    http://www.ebay.com/itm/252401158657?_trksid=p2057...
    I am going to try it but my problem I think I will run into would be the Pos and Neg/input(to board) I looked at this in person and online and there is no definitive markings to mark pos or neg or anything...Ideas?
    my bitvoice couldnt sent any message to the serial port, is it about the activation?
    should I buy it?
    Bitvoice always come out SPeech rejected!!!!!!
    plz help me
