Speed Up Your PC
26,717
55
4
Posted in TechnologyComputers
Introduction: Speed Up Your PC
About: Follow Me for A Gr8 Ride Of tech...
What is Ram (Random Access Memory)? - Just a form of Computer data storage.which allows data item to be read and written roughly in the same amount of time regardless of the order in which data items are accessed.
All your Computer Speed Depends upon RAM, and as we know whenever your RAM fill up more than 80% or fully 100% then our system becomes laggy/unresponsive, since it holds the huge amount of data in it and so the times come when user search for Softwares and all to fix it.
But you can do it with a batch file i.e. without Software
Just follow the steps Provided and you will surely see an appreciable change in your pc speed >>>
Surf it! Learn it! Share it!
Follow Me to get Updates for more Stuff Like this...
Step 1: Step #1
1.Click on Start Menu
2.Search For Notepad
3.Open it
Step 2: Step #2
Now You Have to type Code into it but do this with a right Step:
Codes to write for 512 MB RAM: FreeMem=Space(51200000)
Codes to write for 1 GB RAM: FreeMem=Space(102400000)
Codes to write for 2 GB RAM: FreeMem=Space(204800000)
Codes to write for 4 GB RAM: FreeMem=Space(409600000)
and so on .......
Actually your Computer Calculate things in a regular manner, as many users knows that:
8 bits = 1 bytes
1024 bytes = 1 kilobytes (KB)
1024 kilobytes = 1 megabytes (MB)
1024 Megabytes = 1 gigabytes (GB)
1024 Gigabytes = 1 Terabytes (TB) and so on the power of 2.... (IGNORE! - not a main part of this instructable)
So the Main deal is to write code as per your ram...
i had written codes for 2GB RAM, just to give example in next step>>
Step 3: Step #3
After writing Codes, just save it's type as All Files and give a file name anything you want but with a .vbs extension.
I had written file name as: Ramboost.vbs
See the Pic in next step >>>
Step 4: Step #4
You done All the Steps!
Now just Save it in your desired location and open it....
And So you can now see Some Appreciable Change/Boost in Speed Of your PC.
By the Way For Novice Users! i want to tell that i save that file in desktop to show you >>>
Step 5: Step #5
Just open that file whenever you feel that your Speed Is Slow... ENJOY!
Uhh...One more trick similar to this instructable also works:
Just write the codes:
mystring=(80000000)
and save it as RAM.vbe (so open it whenever you feel slow)
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    4 Comments
    Wow, this is complete rubbish. All you are doing is creating a VB variable that stores 102400000 (or whatever) spaces in memory.
    There's no command called "freemem". All you are doing is saying that 102400000 spaces has a label of "freemem".
    If you've got something maxing your RAM, then fix that, or get more RAM. Even if you managed to create something to "free" your memory (if you're a C language programmer and have a compiler), as the process that was filling your RAM continued running, guess what, your RAM would get full again.
    wow, that is so simple and useful. thx.
    But you did forgotten one more zero in your examples.
    Really! , in which step?
    step #2, looks to me like it is saying 51.2MB rather than 512MB. It is the same for the next ones too.
