Alright, after seeing very few speedball i'bles, and the ones that are here not very good, I have decided to make my own.
Now the first thing you should know is that speedball is very different from woodsball. Woodsball is not as fast paced, and in my opinion, as exciting as speedball. Woodsball involves semi-automatic mechanical guns (I know you can get e-triggers and the like, please dont post about small things like that), while speedball guns are incredibly fast shooting, and are electronic.
So, because speedball is much faster, and requires more complicated equipment, it is much more expensive than woodsball. Starting guns go for about $150, you can go lower, but it isnt recommended. Hoppers are also more expensive, because you need electronic ones, and you shoot a lot more paint.
So if you're thinking about starting speedball, read on!
Remove these ads by
Signing UpStep 1Get A Feel!
However, many people make the mistake of rushing and buying their gear, without doing any research. This is crucial because the equipment in this i'ble can be obsolete in as little as a year. Not only that, but only consider buying gear once you have enough money.
As proved true by a very loyal TechPB'er.
http://www.techpb.com/forum/index.php?showtopic=152223
I am not trying to be rude, but I find it saddening when people believe that a certain barrel is "more accurate". Barrels can only effect efficiency.
So, bore, barrel length and all those myths have nothing to do with accuracy.
But, yes, an insanely overbored barrel would make it less accurate, but I don't think you can buy one that overbored.(unless you use .50 cal)
He says all guns have the exact same accuracy, unless the barrel is unclean, or its bad paint.
Unless you have a huge overbore.
Which is almost impossible to get.
They are an organization dedicated to the science of paintball.
They did the test.
Here is a link.
http://www.techpb.com/forum/index.php?showtopic=184551&st=140
*make sure you are on the last page, around the bottom there will be a question on this topic of discussion.
A g4 does have o-rings. They just aren't on the bolt. Instead they are inside the diameter of the body, where they are much more difficult to access. Still a decent gun.
Buying used is a great way to save lots of money. For example: gen 3 Minis are going for under 200 shipped on both PBN and Techpb. Older model super guns (dm6,7,8 Ego 6,7,8 old intimidators etc) can be had used for the price of a new mid end, but they sill shoot like a super gun. Better yet, if you buy used, when you sell you likely won't lose much, if any, on your investment.
Also, you mentioned a DYE gun with an "accelerating bolt". Every gun has that. If they didn't, the bolt wouldn't move.
The self cleaning eyes you mentioned are actually due to the "eye pipe" which is a removable breach insert that covers the eyes and can be cleaned easier because of this.
A new board is unnecessary unless the stock one can't do 15bps or has bad eye logic, which pretty much only applies to smart parts guns.
Barrel length is completely preference, and bore size does not affect accuracy, but bore matching is the least consistent over the chrono. Underbore for best efficiency, overbore for ease of use.
Bob long is great if you are willing to pay premium for a gun that is very well though out and lovingly engineered. They are also known for efficiency. A Marq with a proficiency engine can supposedly get a case off a full 68/45.
The rotor holds 180, the prophecy holds 220 ish. The fasta is internally identical to the pinokio, except for rubber arm coverings. Eggys are crap. vLocities are available for about $30 now because they are outdated and have unexceptional battery life. Halos can also be found for cheap.
I'd love to contribute to an article about gun posture and snap shooting. Shoot me a PM and I'll link you to some good info.
(and you thought I only played airsoft...)
Also, I think the barrel issue hasnt been proved using a proper test.
I have used a vLocity (select) for a few days before, and I wouldn't recommend them strongly because of the battery issue.
Thanks, I'll reread the sections you mentioned and edit if necessary.
The accelerating bolt thing is probably like smart part's "seal forward" technology.
http://www.youtube.com/watch?v=tCSQgX4cFdg
http://www.youtube.com/watch?v=TYHA8yiLEQ4&feature=relmfu
(he's kinda long winded skip to 1:42)
So use a super efficient gun and a .700 back? I dunno. Realistically, the difference is so negligible (especially in speed ball) that you might as well use the money you would have put into a barrel kit into better paint.
a friend told me they were the best you could get
If you want to be a "paintball sniper" FS rounds in a t9.1 is probably the single most effective setup possible.
http://www.youtube.com/watch?v=7qZB9mYlHfY
http://www.youtube.com/watch?v=Q88Q-tcxQtc&feature=fvwrel
http://www.youtube.com/watch?v=PKFI0d-sfLs
