How to make the Isopropyl 2000 Flash Diffusor at Home. This tutorial will help you make a diffuser for your flash unit. I am not responsible for any ...
Now mark dots 3/8 inch up from the bottom of the bottle edge opposite the cutout that you just made. This edge will be towards your flash in the finis...
Now cut your velcro hook parts into three equal sections, and further divide one of those sections into two smaller sections. Round the bottom corners...
Now, use an industrial hand press to apply the poly-resin snaps to hold the velcro to the plastic bottle. If you do not have such a press, punch addit...
Fold the 2 wide Velcro loop section and wrap it around the top edge of your flash unit, using a little piece of hook section between the flash unit an...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
