3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spent Grain Sesame Bread
Using spent grains from the beer brewing process for baking bread.
Step 1Ingredients
Ingredients
Baking bread with spent grains, requires you to get spent grains from somewhere. If you're not in the lucky position to be a all grain homebrewer like me and many others around the world, you might consider becoming one. It's very rewarding.
Let's get serious again. If you know a homebrewer, ask him or go to a brew pub or a microbrewery. You could ask in a homebrew supply shop as well.
For two breads, you need something in the range of 1-2 cups wet spent grains. I dried two cookie trays about half a inch thick. This will be enough for 5-6 breads. I set the oven to 100C / 212F first to let it dry. This takes a couple of hours with a spoon in the oven door to let the moisture out. Next time, i will let it dry under the sun to conserve energy.
When it's dry, i raise the temperature to 170C / 340 F for around 15-30 minutes to roast it a little bit. Maybe it's a good idea to take some of the unroasted grains to compare the color. Just roast it lightly, otherwise it will get burnt and bitter.
As a next step, i ground up the dried spent grains a little bit. Otherwise, there are whole husks in your bread and they will stick between your teeth.
spent grains 50g / 1.8 oz
sesame seeds 50g / 1.8 oz
bread flour 500g / 17.6 oz / 1.1 lb
active dried yeast 1-2g / 15-30 Grains (0.5-1 teaspoon)
salt 16g / 0.56 oz (2.5 teaspoons)
water 390ml / 13.2 fl oz
I also roasted the sesame seeds a little bit in order to enhance the flavour. As you can see on the pictures, the roasting darkened the seeds only slightly. (Roasting nuts, grains and seeds enhances the flavour in cooking and baking. The seeds, that are on the crust get roasted while baking, but the crumb won't get hotter than 100C / 212F so they don't roast)
Try to get your hands on a strong gluten-rich bread flour, you can look for a 11-13% protein content.
23 comments
Dec 14, 2011. 10:34 AMeiaukea says:
I baked this bread last night and it was incredible! I used my bread machine to mix and knead as t.rohner advised and it was incredible easy. I use the no-knead method but with the machine it was just as simple - I used the pizza cycle in both the sponge/starter stage and the kneading and let it run just in the first kneading stage - I also let the rise happen in the machine. It made two large batard loaves with amazing crust (I use a pizza stone, pan of water on the bottom rack and mist several times during the first 5 minutes). I dried and processed (several cups at a time in the food processor) many cups of spent grains from my husband's weekend brew, which are now stored in pre-measured bags in our freezer in preparation for many more loaves. The only thing I will try differently next time is to substitute some of the bread flour for more of the spent grains - starting with 100g.
Cheers to t. roher for the awesome recipe and extremely complete and easy to follow instructions!
Dec 12, 2011. 10:41 AManipych says:
My wife thanks you.
Oct 25, 2011. 3:02 PMmr squeaky says:
t.rohner, thanks for posting this.
I tried making this bread and it all worked well - however, after i added the second part of the flour, it was still very runny (too much liquid). I added quite a bit more extra flour (100 - 200g and it stayed very liquidly.
I was very careful about measuring the exact amounts of ingredents, apart from the yeast (I may have added too much). Could this be a problem?
Anyway, it was still quite runny when I did the final proofing and it didn't hold its shape (it made cow pat shaped bread!). Despite the shape, it tasted very nice - I think I'm hooked on bread making as well as beer making, thanks to you.
BTW, I used the spent grain from an Irish Red Ale - it gave the bread the texture of wholemeal bread.
Jul 11, 2011. 11:28 PMsunshiine says:
If I had everything I would be baking right now! Thanks for sharing.
Aug 30, 2010. 5:31 PMsuckrpnch says:
I tried this around the time you first published it, but I skipped the preferment. Now that you have convinced me on the preferment, I am going to try it again on my next batch. My old breads actually weren't bad, it just took a bit of experimentation to keep it from being like a brick. I also have switched to all-grain brewing from partial mash and extract since I last used the grains in bread, so I have a lot more grain to get rid of. Thanks! Another idea for spent grains and bread is to take the wet grain and sprinkle it on top of your loaf before you put it into the oven, like you would sesame seeds for example. They get crispy and are kind of nice.
Apr 25, 2010. 3:07 PMpscherer says:
Had I read this two hours ago I wouldn't have thrown away the grain from a batch of beer I am brewing this morning.  Oh well next time.
Apr 18, 2009. 11:42 AMcrazyboy says:
Just made these. I used grain from an imperial stout so the bread ended up brown. I slashed the bread but it didn't turn out like yours after baking. The bread is very dense but looks tasty. It's still hot.
Apr 14, 2009. 10:37 AMbullet-head says:
Thank you for posting this, 5*.
Jun 25, 2008. 6:07 PMbyoho says:
I homebrew, so I'm gonna try this. I imagine if you are using grain from a batch of "hop heavy" beer like an IPA, the bread would be rather bitter though. Any thoughts? Great idea, by the way.
Feb 19, 2009. 6:34 PMlittlejon says:
The bitterness from an IPA comes from the hops not generally the 2 row and crystal grain bill. The only flavoring offsets youd get is if you had a stout grain bill or a porter, where the smoked malts and flavored malts like chocolate, etc may come through. not a bad thing though would taste pretty good i'd imagine!
Jun 26, 2008. 7:51 AMbyoho says:
In many of the recipes I've used, the flavoring hops are added toward the end of the grain steeping. The aroma hops are added later, after the grains have been removed. I haven't worked my way up to all grain yet, started w/ kits, went to recipes that usually include canned malt & grain. I will be "graduating" to all grain soon. I will definitely try your recipe with the next batch. You can't get much "greener" than that.
Jun 4, 2008. 12:41 PMcanida says:
This sounds excellent! Fantastic details, and beautiful pictures. I can't wait to try it.
May 20, 2008. 12:45 AMdan moulton says:
Yum. How about a whole grain brewing ible? Would love to know more.about that too.
May 19, 2008. 10:09 AMskeptikool says:
It looks very wholesome. I've just finished making a bran beer and was quite happy to toss the used bran in with my morning oatmeal. Sure it would have worked in a bread mix too.
May 18, 2008. 3:16 PMthingy says:
That looks delicious. You've obviously made a loaf or two before.
May 18, 2008. 2:53 PMLinuxH4x0r says:
Looks really good! If killerjackalope didn't already do it, I would have featured it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:t.rohner
