Spice Based Natural Insect Repellent
7,949
80
4
Posted
Introduction: Spice Based Natural Insect Repellent
Keeping biting insect away from you can be a hazardous thing these days. With all the chemical-based repellents sold to fight off mosquitoes, it's difficult to know what ingredients you can trust.
One way to ease your mind is to make your own repellent using some commonly available ingredients.
Spices are not just nice aromas you like on your food, but they contain health promoting essential oils, which can be used in many ways.
For instance, the odor of some spices can be used to ward off insects.
Clove, and cinnamon are two common spices that are effective in keeping biting insects away.
Step 1: Ingredients and Supplies
Spices:
Ground Clove
Ground Cinnamon
Supplies:
Ethyl Rubbing Alcohol (or use Everclear, moonshine or Vodka)
Carrier Oils
Filter Paper
Funnel
Mason Jar
Spray or lotion Bottle
Step 2: Mix and Steep
Add one or two spoonfuls of Cinnamon Powder.
Add Clove Powder.
Pour the Alcohol in the Mason jar.
Cover and Steep.
The longer you steep the mixture, the stronger it will become.
If you have the time, you can let it sit a few days, but a few hours to over night should be sufficient to extract most of the essential oils from the spices.
Step 3: Filter Solids From Mixture
Fold a coffee filter twice to make a quarter-round.
Place the coffee filter in the funnel.
Place the funnel in a container large enough to hold the liquid..
Pour the mixture slowly into the filter, letting it drain into the jar.
If the filter begins to clog, slow down, or stop and clean out or replace the filter. You can also scrape the sides of the filter paper with a spoon or dull knife to keep the flow going. Be careful you don't damage the paper, allowing solids to pass.
When finished, let the liquid settle.
If there is still sediment in the bottom, filter it a second time.
Step 4: Bottle and Add Carrier Oil
When the liquid no longer contains sediment, pour into your container.
Add a carrier oil that is non-toxic and can be used on skin. Don't use hydrogenated vegetable oils, but you can use olive oil. The reason for the carrier oil is two fold. Alcohol will dry your skin. The oil will also keep much of the essential oil from quickly evaporating.
If you're going to use the repellent as a spray, use a light oil. If you're making a lotion, you can use something like Jojoba Oil which is heavier, and less easily sprayed. You may experiment if you wish.
Step 5: Suggest Use
Warning: Test before use on a small area of skin for allergic reactions.
Shake well before using.
Spray exposed areas of skin. Spray your hand and wipe it on your face, or close your eyes and spray.
The effect should last a couple hours, depending activity level.
Use often without worry of dangerous chemical poisoning.
If you have a lot of mosquitoes in your yard, you might want to build a mosquito trap.
https://www.instructables.com/id/Why-You-Should-Mak...
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    Thank you for this tutorial :) It is an improvement of the one I thought out
    Look what I just found out.
    http://www.naturalnews.com/055221_DEET_neurotoxin_Zika_virus.html
    September 07, 2016
    by Mike Adams, the Health Ranger
    Tags: #DEET, #neurotoxin, #Zikavirus
    "I've just released a hard-hitting mini-documentary that explains how DEET insecticide is one part of a binary chemical weapon that targets your brain for destruction.
    The other part of that chemical weapon is found in carbamate pesticides which inundate the non-organic food supply. Once you combine these two, you get hypertoxicity to brain cells via "acetylcholesterase inhibitor chemicals," leading to mass confusion, fear, memory loss and an inability to think for yourself.
    This video explains why the mainstream media is urging everyone to spray DEET all over their skin while carbamate pesticide chemicals are carpet bombed onto civilian populations (and the food supply). It's all a deliberate act of chemical warfare against YOU, and it's being waged for a specific purpose that's explained at length in the video. (Hint: It's no coincidence a major presidential election that depends on dumbed down voters is taking place in less than 70 days...)"
    What are the measurements of all of the ingredients, especially the carrier oil? This sounds great!
    It doesn't really need measurements. Just wing it. From the looks I added about 20-25 per cent carrier oil. The more oil you use, the longer it will last on your skin, but the less potent it might be. You can experiment and let me know your results.
