3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spice Grinder Hack
Spice Grinder Hack
This was an idea I came up with one night while making dinner. Well, part 2 of an idea. The first one was easy. Just pop the top off after you have used up/emptied out all the spices (in this case rainbow peppercorns) and add your own mix of spices. - later found here. My wife and I like oregano, rosemary, dried garlic, and basil.
Obviously someone else thought of an electric grinder and they can sell for $10-$300 (I did a Google search)
This is a 10 minute hack costing less than the $10 the cheapest ones sell for. (assuming you already have a drill)
I live in an apartment so I don't have a garage, tool shed, or even a work area. So as you may be able to tell from the pictures, I did this on the kitchen floor. That is how easy this is.
Plus - it's fun to use power tools to cook with!
Step 1What you will need
What you will need
Materials:
. A grinder of some kind. I got mine from W-M grocery. You can use any brand as long as the size works with the base
2. A base to attach screw. Again taken from a empty spice container. As long as the sizes are close
3. Glue. I used JB weld. You could also use Hot glue but I chose not to because most of my spices are on the back of the stove (heat source)
3A. A mixing stick for the JB weld.
3B. Something to mix the JB weld on (not pictured)
4. A small screw. Not sure where this came from, but it would be best to use a flat screw head instead of rounded. (it makes the grinder wobble)
5. Toothpicks (optional, not pictured)
Tools:
Sandpaper
Screwdriver
Extra battery powered screwdriver or drill
10 comments
Dec 3, 2011. 3:25 PMgrannyjones says:
A very cute idea, but I was hoping for directions
on how to re-use the 'non- reusable' grinders-
the ones you can't take apart.
When they build stuff like that it is so annoying.
Mar 2, 2012. 12:18 AMsideways says:
I cut out the some of the white plastic center of the throwaway grinder, avoiding getting too close to the edge where the grinding teeth are. The hole is maybe a half-inch across; just big enough to refill. I had to saw away quite a bit using an old serrated steak knife. I suppose a drill might work if you have a big enough bit. I didn't at the time.
I used one of those foam squishable earplugs as a plug for the hole. It squished down to fit, then expands. Yes it was a clean, new one. A piece of cork would probably work.
Ive refilled it maybe 5 or six times now. It still grinds kind of ok, but might only last for a couple more fillings. Considering they probably weren't designed to be used over and over, it's held up pretty good.
Dec 12, 2011. 4:15 PMrstenger says:
Give the 'non-refillable' spice grinder to someone strong. it will come apart with just bear hands. I did it yesterday to add more black peppercorns. I haven't had one break on me(done 4 now), how ever do this at you own risk.
Nov 25, 2011. 6:08 PMdeclanthedork says:
This will be great for my (legal) herbs!
Nov 25, 2011. 7:11 PMthe walking stick says:
they'd have to be rally really dry to grind with this, since the grinding mechanism is most likely plastic. if the legal herbs were fresh or moist, it might just smush them......
Nov 26, 2011. 2:00 PMdeclanthedork says:
hmm yeah, I guess I'll just stick with the scissors and cup
Nov 27, 2011. 2:58 PMdeclanthedork says:
Perfect, thanks!
Nov 25, 2011. 7:42 PMgarnishrecipes says:
Whoa! This is so cool. I would never have thought of this- we're going to give this a go.
Nov 25, 2011. 2:05 PMscoochmaroo says:
Very clever!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:GrassHopperJonez
