Spider Massacre 2.0 - Compact
4,948
16
154
Published
Introduction: Spider Massacre 2.0 - Compact
heey guys
so this is my upgraded version of the normal Spider Massacre. it's much smaller and uses fewer pieces and it's also way more sturdy.
i said that i would post this instructable three months ago but there were some minor problems with my camera (the spiders invaded my room and ate it).
i hope you all like it and have fun. plz rate this thing and comment or give feedback or whatever. oh, and i'm not liable for anything stupid you do with it.
Step 1: Building the Handle
ok let's start building this gun. because this version is much smaller than my original Spider Massacre, i also have less steps. the first step will be building the handle.
pieces needed:
2 yellow rods
6 yellow connectors
5 gray connectors
5 light gray connectors
Step 2: Building the Trigger Mechanism (part 1)
this trigger is almost similar to the trigger of the original Spider Massacre, it's just a little more sturdy.
pieces needed
3 blue rods
6 white rods
7 green rods
2 white connectors
3 green connectors
8 red connectors
10 gray connectors
1 blue spacer
1 black Y-shaped connector
Step 3: Building the Barrel (part 1)
the barrel consists out of two parts. obviously, this is
part 1...build this
pieces needed
2 red rods
8 yellow connectors
5 orange connectors
2 red connectors
2 gray connectors
Step 4: Building the Trigger Mechanism (part 2)
this is where we complete the trigger mechanism and add some things so that we can later put everything together.
pieces needed
the barrel from 'step 3'
the trigger part from 'step 2'
2 blue rods
6 orange connectors
Step 5: Putting It All Together
in this step we will put everything together we've made so far.
pieces needed
everything from the previous steps
Step 6: Building the Barrel (part 2) + Firing Pin
this is the second and last step of building the barrel. you can choose to build a short, medium-sized or long barrel, or no barrel at all. in that case, simply skip this step
pieces needed
short barrel: yellow rod + 3 gray connectors + yellow connector
medium-sized barrel: red rod + 10 gray connectors + yellow connector
long barrel: gray/black rod + 20 gray connectors + yellow connector
Step 7: Extra Part (optional)
you dont need to built this part, but it's useful for mouting a scope or sight on the gun or attaching a bipod. you can also build it simply because you like how it makes the gun look...or something like that
Step 8: Loading, Firing and Other Stuff
for those who have never ever fired a knex gun before, pull back the firing pin until you hear a 'click' of the trigger blocking the firing pin. load ammo into the barrel. aim. pull back the trigger to fire.
currently i am working on a new project. it's a assualt/sniper rifle(whatever you want to call it). it's single-shot, but i'll also be making a mag version. the reason for always making guns single-shot is that they're just way more powerful. i let you all know when i'm gonna post my next instructable.
have fun and don't do anything stupid with it.
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
    154 Comments
    please make the rifle instructable
    bendy blue rod?
    Definitely one of the better guns i have seen but it fires really high so i am having a hard time aiming it (i am using medium barrel).
    i give u a tip use a small barrel so the rod cant move around much
    although i didn't extend the barrel or add the rail, i like to have those options :D
    Probably one of the more original trigger designs I've seen, great job!
    5*
    This reminds me of Donut massacre 64 my friend says this is Spider MASCARA
    i already have. i refined and upgraded the rifle you see in the last step into something a million times better. - it's got better firepower - it's sturdier - it's more accurate - the gun has a rail on top of it - better trigger - better handle - safety switch - it's got the unique ability of changing from assualt rifle to sniper rifle in a few seconds by replacing the barrel system. one barrel has a mag attached to it (22 rounds). the second barrel is for a single shot sniper rifle for ultimate power and accuracy. i hope that makes up for my long absence ill post it when enough people are interested in this rifle.
    Holy crap man that sounds so epic! Post please!
    i will just gotta get some batteries for my camera. check my orangeboard for more info on the release date
    is there an instructable for the gun in step 8??
    there will be. i refined and upgraded the gun you see in step 8. i'm gonna post it when there is enough interest in the gun.
    jfnkgjsdfjxfcgnhjswhedruweiruoiwuerpotiuweoptuweportuweotupowiepowierpowiru
    true trig?
