Introduction: Spider Massacre V3.0 by Mrbox
About: Just a plain old brown box ;D
(To start I credit frozenfire 99 for his spider massacre 1, 2 and the design was based off of massacre 2 so he gets 90 percent of the credit... I get the other 10% for the mods...)
(another thing NOTE this is not the real v3.0 made by frozenfire 99 but it is a mod by me)
Able to use a red or grey rod for ram... (Mine uses red cause I don't have any black rods anymore...
-Shoots through cardboard (ALL THE WAY as in bullet goes front and back through the cardboard) from 13.2 feet without sharpened ends
-Shoots a grey rod 40-50 feet ... the gun isnt made for distance
-Accuracy has been improved (this gun is made to shoot red rods or lower grey rods would flip through the air, to fix that simple replace the yellow rod on the bottom of the gun to a red one then add grey connectors...)
-Bullet lock
-Trigger improvement (Mostly cause the last trigger always broke
-Handle Improvement (Again mostly cause the last handle broke
-Sights
-Reinforced structural design
Oh and do rate pwease =)
This is an old picture.... thats why its so clear and beautiful!!
(From my old camera before it got destroyed by this gun when it was in testing stage)
Step 1: Knex Pieces Need to Make the Pistol!
Rods:
Green rods - 10
White rods - 14
Blue rods - 7
Yellow rods - 8
Red rods - 4
Grey rods - 0
Black rods - 1 (This isn't really needed but if you were to use a black rod ram you'd need to replace one yellow rod with one red rod....)
Connectors:
(1 slot) dark grey connectors - 24
(2 slot) light grey connectors - 5
(2 slot) orange connectors - 28
(3 slot) red connectors - 12
(4 slot) green connectors - 7
(5 slot) yellow connectors or "half circles" - 12
(8 slot) white connectors or "full circles" - 3
Special pieces:
Blue spacers - 1
Grey spacers (which are 3 blue spacers) - 0
Tan clips - 3
Black clip (which acts like a bullet lock) (if your confused on what piece this is don't worry ill take a picture of it...) - 1 This could be replaced with a two slot grey connector... but it would make it look ugly... but it does do the job!: 1
Y-clip connetors - 3
Other
Tape
Rubberbands
Your brain
Step 2: The Handle
Improved handle
Pic 1 - completed handle
Pic 2 - connect the six yellow connectors to the two yellow rods
Pic 3 - second view of handle
Pic 4- connect the oranges to the handle
Pic 5- second view of handle
Pic 6 - third view of handle
Pic 7 - connect two yellow rods onto the orange connectors and connect two oranges to the yellow rods
Pic 8 - second view of handle
Pic 9 - third view of handle
Pic 10 - push two yellow rods into the holes in the orange connectors and one in the mid of the handle
Pic 11 - second view
Pic 12 - third view
Pic 13 - fourth view
Step 3: Handle Continued / Trigger
Pic 1 - connect
Pic 2 - second view
Pic 3 - connect
Pic 4 - second view
Pic 5 - build
Pic 6 - connect
Pic 7 - second view
Pic 8 - connect
Pic 9 - second view
Pic 10 - third view
Pic 11 - trigger: build
Pic 12 - second view
Pic 13 - put the trigger into ther white connetor and attach with a blue rod
Pic 14 - second view
Pic 15 - third view
Pic 16 - build and add to trigger
Pic 17 - second view
Pic 18 - third view
Pic 19 - connect blue rods
Pic 20 - FORGOT SORRY!! Add a grey connector to the trigger as shown in pic
Pic 21 - second view
Pic 22 - add a white rod with 1 blue spacer
Step 4: Barrel (note This Is Not the Same Barrel From V 2.0)
Pic 1 - build
Pic 2 - second view
Pic 3 - conncet
Pic 4 - second view
Pic 5 - third view
Pic 6 - connect
Pic 7 - second view
Pic 8 - third view
Pic 9 - fourth view
Pic 10 - fifth view
Pic 11 - add red rod
Pic 12 - adding the bullet lock
Pic 13 - connect
Pic 15 - third view
Pic 16 - fourth view (where the red rod connects)
Pic 17 - fifth view ( where the red rod connects)
Pic 18 - connect the ram (which is a red rod and an orange connector, it connects onto the grey connector keeping it in place when you pull it back, when the gun is completed)
Pic 19 - second view
Pic 20 - third view
Pic 21 - fourth view
Pic 22 - fifth view
Pic 23 - sixth view
Pic 24 completed barrel
Step 5: Trigger Continued
Pic 1 - connect a blue rod and add three grey connectors
Pic 2 - second view
Pic 3 - third view
Pic 4 - fourth view
Pic 5 - fifth view
Pic 6 - add a green rod to the three grey connectors and then add three more grey connectors to green
Pic 7 - connect green connector and two grey connectors to the blud rod
Pic 8 - second view
Step 6: Putting It All Together
Pic 1 - connect
Pic 2 - connect
Pic 3 - connect
Pic 4 - connect
Pic 5 - connect
Pic 6 - connect
Pic 7 - second view
Pic 8 - third view
Pic 9 - fourth view
Pic 10 - fifth view
Step 7: Adding the Rubberbands
Pic 1 - Pic 5: attaching ram rubberband
Pic 6 - Pic 8: attacing trigger rubberband
Step 8: Further Mods
Pic 1 - connect
Pic 2 - second view
Pic 3 - connect
Pic 4 - second view
Pic 5 - third view
Pic 6 - connect
Pic 7 - second view
Pic 8 - third view
Step 9: Con Gratz You Have Reached Lvl 0!!!! Im Joking ... FINISHED!!!
I AM NO WAY RESPOSNSIBLE IF YOU WERE TO DO SOME OF THE FOLLOWING!
Shoot your friend, dog , neigbor, your eye, your friend eye, a box T.T, a computer, yourself, the gun, other knex pieces, etc...
Throw the gun at your friend, dog, neighbor, cat, turtle, snail, spider, taurantula, whatever
I am also not responsible if you decide to burn the gun or be an idiot and set your house on fire with this gun or even shoot your house with it or destroy our planet with this or even shoot me with it...
NOTE i had to use a magical postion to build this gun and take the pictures, cause i needed arms!
And now for a random picture(s)!
