Introduction: Spike Ring
This ring creates the illusion of a spike going through your finger, although the ring is SO lightweight you probably won't even feel it. **This project DOESN'T use actual spikes, they're just simply cone bead caps! Much easier to find than real spikes.
Step 1: Supplies
Supplies:
- Jewelry pliers
- Super//E6000 glue
- Adjustable ring blank
- 2 cone bead caps
- Jewelry pliers
- Super//E6000 glue
- 2 cone bead caps
Step 2: Prep Ring Blank
If your ring blank has a loop on it, twist it off with the pliers. Separate the two ends of the ring to widen up it up a bit.
Step 3: Bend Ring Blank
Bend each of the ends out, making them as flat as you can.
Step 4: Glue Bead Caps
Glue one of the prongs into the inner top part of a bead cap.
Step 5: Repeat on Other Side
Repeat on the other side. Let dry.
