3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spike Your Speakers
Spike Your Speakers
Adding spikes to the bottom of your speaker cabinets can be a very economical way to improve their sound by isolating them from the surface they are resting on.  In my case, the floor of my apartment.  This modification was done primarily for the benefit of my downstairs neighbors, because I like to play bass heavy music and getting the speakers up on spikes will reduce the amount of bass transmitted through the floor.
That's the idea, anyways.
Careful if you just have hardwood floors.  If you support heavy speakers this way, they will dig right into the wood.  You can be creative with protecting hardwood floors.  One common method is to put pennies under the spikes.  It is also common to see spike sets sold with small platforms for this purpose.
Here is a lengthy article
on what may or may not happen when using speaker spikes.
noahw also has a short write up on this subject on his instructable.
Step 1Parts List
Parts List
Required
Speaker spike sets, I got the cheapest ones I could find since I didn't pay anything for the speakers and this isn't audiophile gear.
You can get pretty fancy ones if your gear warrants.
Drill
Hammer or Allen Wrench depending on the design
Optional
Adhesive  -  A couple reviews at Parts Express recommended using an adhesive like Liquid Nails to improve the seal of the threaded inserts.  I picked up something called Seal-All at the hardware store, but any decent glue should do the trick.
Vacuum Cleaner to suck up saw dust (for the carpeted apartment hobbyists out there).
15 comments
Jan 22, 2012. 8:07 AMASCAS says:
Spikes are only good for carpeted floors.
Apr 25, 2012. 4:04 AMcurious youth says:
false. read what he says about protecting hardwood or other flooring. i have many applications (not on carpets) where sound is better reproduced with the speaker on the spikes
Apr 25, 2012. 5:27 AMASCAS says:
Ohh, sorry, I didn't know that.
Jul 3, 2011. 12:00 PMbiolethal says:
wait... spikes would do the opposite of isolating the speakers. im no audio expert, but using simple physics, i can tell you that they are actually not helping isolate your speakers, but are probably anchoring your speakers to the ground more. since dry friction is a function of mass, gravity and the roughness of the area in contact, and not of surface area, theoretically you would not have a decrease in friction between the floor and the speaker if the point of the spikes is to isolate the speakers by using the false concept of less surface area = less friction = isolation. in fact, because the spikes will slightly dig into any surface that is softer than them, that would increase the friction of the speakers to the floor, and effectively anchor them, which could also be desirable. no hatin' or offense intended. great instructable!
Jan 14, 2012. 5:19 PMmettaurlover says:
And yet audio experts disagree. I wonder why...
Jan 14, 2012. 6:19 PMbiolethal says:
I think it all goes back to "I think it sounds better, because i did something to it"(placebo effect) audio has become so advanced nowadays, that the individual differences that such changes may make are so minute that the human ear cannot possibly tell the difference. Air humidity or temperature probably makes much more of an impact than if speakers have spikes or not, unless your speakers are sliding around while they play...
Jan 14, 2012. 6:31 PMmettaurlover says:
Assuming a solid surface, a tiny point of contact is going to transfer MUCH less sound than having the entire base touching it. That's why speakers have large surface area, instead of having just the actuator.
Jan 14, 2012. 7:45 PMbiolethal says:
two things:
speakers need to have a large surface area because air is not solid, so they need to contact as much of it as possible to achieve the desired amount of air movement. however, you don't need a large point of contact to move a solid mass. try pushing air with the tip of your finger. wasn't very effective, was it? now try pushing a solid object, like your mouse, with the tip of your finger. worked, didn't it? that proves that you don't need a large point of contact to transfer movement, or in your case, sound, through a solid object.
second, assuming the spikes do not slide around on the ground, and assuming their elasticity is negligible, you have no effect on speaker movement in relation to the ground. the speaker cone travels parallel to the plane of the ground, so any third-law forces it would produce (the forces that would move the speaker) will be in the exact opposite direction, parallel to the plane of the ground. so the speaker will not vibrate up and down, only forwards and backwards, transferring sound not up and down, but forwards and backwards. put your spiked speakers on a hardwood floor, with pennies under the spikes, and try pushing it. now take the same speaker, without spikes, and try pushing it. it takes the same force to push the speaker. so the speaker would move exactly the way it did before.
Feb 11, 2010. 12:47 AMpower says:
 lol you should try to repair that dustcap
and I've added some spikes for my speaker,sounded the same but with less complains from my dad :D
5 stars
Dec 2, 2010. 10:06 PMThe nerdling says:
one way to fix it is to get a small screw driver and poking a hole at the back ang using a pen poke it out from behind
Jul 1, 2011. 6:32 AMSyncubus says:
Seems you might be able to pull it out with a vacuum cleaner hose? Is it too fragile for that?
Dec 9, 2011. 5:59 PMschumi23 says:
o had a speaker cone with the same problem, and managed to mostly get it out with a dab of hot glue, quickly grab a piece out (ok, its hot, deal with it(its not really hot enough to burn you...) then let it dry for 30 seconds or so, then pull it off, it should work... it did for me.
ps: Why is my firefox spell check putting itself on french by default?
Oct 9, 2011. 9:24 PMbowmaster says:
The problem with this is, I listen to so much dubstep the spikes would vibrate themselves into the floor.
Jan 13, 2010. 8:09 PMJustinph5 says:
 Your first article suggests using pennies under the spikes for hardwood floors. You could suggest that to people with hardwood floors, so they won't get scratched.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:teeps
