Spinning Button Toy
4,262
8
Published
Introduction: Spinning Button Toy
About: bestcodes.weebly.com
This is a fun and easy little toy you can make in less than a minute. Check it out!
Step 1: Gather Materials
you will need...
String
A Button
Something to cut the string with
Step 2: Cut the String
Cut the String about the size of your arms spread out.
Step 3: Thread the String Through the Button
Put one end of the string in one hole and the other end in the other hole.
Step 4: Tie the Ends Together
Tie the ends of the string together so the Button won't falls off.
Step 5: Make It Spin!
To make it spin twirl it up in the air and then pull the strings apart. If you do it right it should twirl back up for you, then you pull the strings apart again. Hopefully you understand the directions, that's as good as they're going to get. It takes some practice but you'll get it.
Step 6: (Optional) Add Key Rings
If the string hurts your fingers just put a key ring on each side.
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Once you get it spinning really fast you sneak up behind your sister and stick it next to her hair and run really fast when she starts screaming and chasing you. Oh the memories.
    good i frogot about this utill i seen this bring me back when i kid i used to make these
