3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spinning EL wire techno vortex thingee
I've been playing with EL wire a lot lately. I was inspired by guerroloco's EL Wire Eye Candy instructable (http://www.instructables.com/id/EL-wire-eye-candy/), specifically the "Happy accident" described in step 6. Specifically, I was curious about what sort of visual effects I could get out of combining spinning with EL wire strobe effects.
I was pleased. I can best describe the effect as a ghostly colorful vortex. It's very pretty & trippy, and meshes well with other techno effects.
This instructable describes my first prototype. While still crude, it's effective enough that I've made three duplicates so far, and plan to deploy as many as I can make at the upcoming Critical Massive festival, which is the Seattle-area Burning Man community "regional burn". I'll likely also bring a variant of this to Burning Man itself.
My camera works pretty poorly in low light, so the in-action pictures and video barely do it justice. It's most fun when viewed from below; we've spent far too much time already lying on the basement floor gazing up at the pretty swirl.
OK, on to the instructions.
Step 1A peek at the goal
A peek at the goal
First, I'm going to to show you the end result. It's fairy simple: a wooden "fan blade" attached to a small motor, and a pair of EL wire strands powered by a techno strobe dangling off each end. This is attached to the ceiling. When the EL wire driver is set to strobe, the motor is turned off, and the lights are turned off, the party begins.
The blade is attached to the motor using a collet, and the motor is secured to the ceiling using a hose clamp, as shown in the second picture.
There's a thousand ways to accomplish this task, and by no means am I claiming that this is the best way. It was, however, what I could quickly accomplish using what I happened to have lying around.
3 comments
Nov 9, 2010. 12:42 PMguerroloco says:
Thanks for the credit, by the way; the guy that did this Instructable totally ripped off my idea, and made a crummy Instructable out of it.
Oct 20, 2010. 12:56 PMguerroloco says:
Nice!
Jun 6, 2009. 12:26 PMlieuwe says:
does your cam have a shutter time setting(sometimes called ev)? if it does try setting that longer(but hold your cam still!)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Mike Begley(SeattleLumin.com)
Hi! I'm a general-purpose maker geek, living in Seattle. Interests include beer brewing, robotics and woodworking. I like to go camping in the desert. I enjoy hiking to hot springs. I'm learning ho...
more »
