3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build this amazing Spinning Rainbow Light Wheel!!!
Step 7Making an electrical contact between aluminum tape rings to wire
This is another difficult part, making an electrical contact between aluminum foil tape rings to the wire without causing so much friction...
I will tell/show you how I did mine, I used some thin flexible steel wire to make an electrical contact with the foil tape.
First I made a small hole on the motor's holder and made a loop on the flexible wire and put two ends of the flexible wire in the hole on the motor's holder and make sure the flexible wire is gently touching the foil tape and glued the flexible wire in place and I soldered a piece of wire on one end of the flexible wire.
I also supported the flexible wire with some pieces of wood that is glued onto the motor's holder next to the flexible wire to stop the flexible wire wiggling everywhere. And I did the same thing to the other flexible wire.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
779
Author:Plasmana
 "Energy cannot be created nor destroyed!"
more »
