Introduction: Spiral Cut Potatoes
The only problem is spiral potatoes that they are only sold at fairs and carnivals around here. Instead of waiting for the next fair, I decided to make my own spiral cutting machine. With the help of your drill, you too can have your own spiral cut potatoes.
I made this out of junk pieces of wood someone threw away.
.I made this for the Power Tools contest, If you enjoy it Please vote!
Step 1: Supplies
You Will Need
Potato
Wooden Skewer
3 Pieces of Wood (any size will do, Just make sure they match in height when you setup the wood)
Dowel
Blade
Step 2: Construct
- Attach two of the pieces at a 90 degree angle.
- Cut Dowel in half
- Glue Dowel to piece of wood(Not the base)
- (Not Shown) On the other piece of wood, drill two holes so the dowel fits and slides in between
- On the piece of wood the dowels are on, put a blade on the top. Be careful. For best results slightly angle the blade
Cool! Your done with construction
Step 3: Check
Check to see if what you have matches mine. Notice the piece of wood with the two holes for the dowels is in this picture ( Sorry for not putting a picture in the last step)
Step 4: Rest for Drill
Sand out a ditch to make a rest for your drill. Simple Enough.
Step 5: Impale the Potato
Stick the Skewer into the potato and put the skewer into the drill as if it was a drill bit.
Step 6: Cut the Potato
To cut a spiral potatoe
- Rest your potao drill on the rest
- Turn the drill slightly to avoid the dowels
- Press the wood/drill/potato closer to the blade
- As you push the drill and wood the potato will be cut on the blade
TIPS
- Use equal force
- Slower Pushing makes thin cuts
- Fast Pushing makes thicker cuts
- You might want to peel the potato before you cut it
Step 7: Peel Apart
Peel part the spirals. Be careful, if you are not gentle your potato might break.
Step 8: Cook and Eat
To cook simply deep fry as you would deep fry normal french fries. Next salt and season according to taste. Now you can finally eat your spiral cut potato without waiting for a fair or festival.
Hopefully someone will help with the Potatoes Potato's issue... :)
Follow Here Thank You!
Second Prize in the
Power Tool Kitchen Contest
Woodworking Contest
