Spiral Wood Pendant Necklace.
434
11
Posted
Introduction: Spiral Wood Pendant Necklace.
I had a piece of white oak which came from a tree that was cut down in 91. When I was growing up the tree was always there towering over me. It's sad that the tree is no longer with us but at least now I can keep a part of it with me wherever I go.
Tools & materials needed:
Safety glasses
Hearing protection
dremel rotary tool with router bits & fiberglass cutoff wheel
template
drill & small bit
flexible super glue
elmers glue
acrylic paints
wood stain, pre-stain, polyurathane ( I used miniwax brand )
sandpaper 150-400 grit depending on how smooth you want your piece
woodburning kit
tiny screw, screwdriver, & small solid strand copper wire
Faux strand
Step 1: Glue Design Template Over Wood.
First thing needed was a design so I searched until finally deciding on a spiral star. I printed it out proper size & used elmers glue to glue it on my piece of white oak wood.
Step 2: Prepare for Lots of Cutting.
When the glue dried & template was firmly in place I got out my dremel & used a combinate of 2 different sized routing bits as well as a fiberglass cutting wheel to carefully cut along the lines. I then kept routing more & more wood away the entire depth of my slab of wood (probably 1/2"-3/4 thick) which took a couple of hours. Once I had the shape cut out of the slab I then focused on rounding the edges with the router bit & fiberglass cutoff wheel. I used a penny to mark a circle in the center to cut out which I originally planned on inserting a penny with my birthdate but decided to do a design there instead. I used the router bit to cut out the center circle 1/8" deep. I also cut out little spiral triangular sections 1/8" deep on each of the 8 spiral arms. Once all this cutting was finished I used 150 grit sandpaper to sand it down a bit smoother. I then used a wood burner to darken areas of the wood giving it an aged look as well as smoothing it up a bit more.
Step 3: Stain & Paint.
Now I was ready to stain my piece. I used miniwax prestain & dipped the entire piece in & wiped off excess with a cloth. I allowed about 5-10 minutes for the prestain to soak in & then used gunstock oak miniwax stain & dipped entire piece in it & removing excess with cloth. I let the stain dry overnight & next day used acrylic paint to add the color to the center & spiral arm recesses. I let this set overnight since the paint was thick to make the center spiral effect & wanted to be sure it was dry before coating it in miniwax polyurathane.
Step 4: Adding the Hanger & Polyurathane.
With the paint dried I made a hanger for the necklace out of a small piece of solid copper wire. I found a tiny screw 1/8" long & drilled a tiny hole for the screw. I shaped the copper with small pliers & had the twist of the wire going clockwise since that's the direction the screw would be tightening. Once I got the screw snug I folded the copper sticking out back over on to itself & used flexible super glue around it all using a toothpick to get it into all the tiny places around the screw & wire. I allowed the glue a few hours to dry & then used a piece of wire through the necklace loop to hang the piece from so I could dip it in the miniwax semi-gloss polyurathane. This not only helps protect the piece but make it's look nice as well. I allowed overnight for it to dry & used a strand of faux to run through the loop & tied the ends to finish my necklace.
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
