Introduction: Spiral Galaxy Rings
Picture of Spiral Galaxy Rings
First of all, you might think the title is a bit weird. I'm going to explain it in the last step :)
Second of all, the person who designed this ring, is this amazing Etsy shop owner called theWRAPstar:
The ring
The shop
I love all the beautiful wire and bead stuff you can find in that shop, but when I saw this ring I had to try to make it. The ring with the light blue beads was my first try, and I'm really happy with how it turned out. Of course, when two people make the same ring, they end up with two different rings. I think the original ring has a bit more of a round, higher look, where mine is shaped a bit more oval, but I like that. It just makes everything handmade unique. The instructable will show you the steps I took to make this ring. I hope you like it!
Step 1: Materials
Picture of Materials
To make this ring, you will need the following:
- wire
- flat nose pliers
- cutting pliers
- 2 coloured beads
- 2 metal beads
- round object to wrap your ring around
Step 2: Cut a Piece of Wire
Picture of Cut a Piece of Wire
Take your wire and use the cutting pliers to cut off two pieces of wire with a length of about 20 centimeter. I used most of it, just a few centimeter had to be cut off in the end.
Step 3: Wrap!
Picture of Wrap!
Make sure the two pieces of wire are straight next to each other. When they come across each other on the other side, wrap one side around the other. When you've done that, wrap the other side also.  Continue wrapping them for about  half a circle (just a bit more) to create a circle.
Step 4: The Beads
Picture of The Beads
Let the top two wired stand apart from each other. Add one of the coloured beads to the bottom wire. Now you can take it off the round object, if you hadn't already done that. Bend the wire down a bit, until the wire is crossing the ring part at a point you could call it straight. Coil the wire around the ring three times. The way I find easiest is to fold the wire in half and put it up through the ring, then back down.
When you are done coiling, cut the remaining wire off. First I cut off a bit away from the ring, then I cut again to stop the wire from sticking out.
Now take one of your metal beads and add it to the top wire. The following steps are basically the same as with the other bead, the only difference is that I coiled it four times instead of three.
For the wires on the other side, you can do exactly the same.
Step 5: Done! and an Explanation of the Title
Picture of Done! and an Explanation of the Title
When I was done making this ring, it somehow reminded me of galaxy. I searched google images and found what I was looking for: Barred spiral galaxy.
I hope you liked this instructable, if you have made this ring, I would love to see it!
Mabear52 (author)2017-12-05
I love this ring and your right it does look like a Galaxy. Was wondering what it would look like with a copper wire. Have you tried that? Just curious if you did, like I said I love it. Great job. I will be making some of these for Christmas gifts.
emilyvanleemput (author)Mabear522018-01-04
I think using copper wire could look great, but be sure to use coated copper wire, you don't want to stain people's hands!
cvolz (author)2016-05-09
very nice! I'll have to try this :) thanks for posting
emilyvanleemput (author)cvolz2016-06-01
Thanks!
beadinggem (author)2015-09-11
Really clever to make it reminiscent of a galaxy! Must make it for someone I know who loves astronomy. Will share on my blog so others can come here to try it!
I'm glad you like it!
TenaciousBalloonFox (author)2015-03-24
This is beautiful! Thank you!
Thank you!
JenniferC17 made it! (author)2015-06-20
I missed a step, the last sentence of step 3 where it said to wrap it again :) But I think it still turned out pretty. Thanks!
It looks great!
lokaa.loky (author)2014-12-14
I really like it
Thank you!!
doodlecraft (author)2014-07-09
I love this! :) You make it looks so doable! I may just have to give some wire rings a go! :)
Thank you!! I'll warn you in advantage - it's quite addicting ; )
dhogue (author)2013-12-17
I agree with mole1, these would great as ear cuffs! Wow, you're amazing! I actually like your ring better! Thank you for the instructable!
emilyvanleemput (author)dhogue2014-01-21
Thank you so much!
mole1 (author)2013-11-14
Love the rings! Any chance of your making a similar ible for ear cuffs?
emilyvanleemput (author)mole12013-11-17
Thanks! I actually haven't made ears cuffs before, maybe I'll give it a try!
Shadri (author)2013-09-28
This is gorgeous! And the instructions are very detailed. I've never made wire jewelry before, but I just might have to try now...
One question, what type of metal is your wire made of?
emilyvanleemput (author)Shadri2013-09-28
Thank you so much! I'm using silver plated copper wire I think.
loveinamist (author)2013-09-08
You inspired me! In typical DIY fashion, I didn't have quite the same supplies on hand, so I modified the design. I had 16 gauge wire and the beads that would fit it were bigger, which inspired me to change the placement as I constructed it.
It's great!
Yolo77 (author)2013-09-07
Awesome!
emilyvanleemput (author)Yolo772013-09-08
Thanks!
vnh1970 (author)2013-09-06
Wow!! That is an *awesome* ring. Thanks for sharing this tutorial. :)
emilyvanleemput (author)vnh19702013-09-06
Thank you!
bgunville (author)2013-09-06
Nice work however I like the doily under your rings.
Thanks, I like it too :)
bpersun (author)2013-09-05
This is an awesome ring and you made the instructions easy to follow with the great photos...
What gauge of wire did you use?
Thanx
emilyvanleemput (author)bpersun2013-09-05
thank you. I used 0.8 mm wire
Trena765 (author)2013-09-05
I am wanting to try to make this. I have never made jewelry and this looks like something I would like to try. Could you please tell me the type of beads and the sizes you use. As well as to the size of wire. Thanks Trena
emilyvanleemput (author)Trena7652013-09-05
The coloured beads are glass beads of about 4 mm. The metal beads are smaller, I'd say somewhere between 2 and 3 mm. The wire is 0.8 mm.
craft-n-genius (author)2013-09-05
I SO want to make these. I haven't been making a lot of jewelry lately, but I think now is the time to make something... this!
Thanks!
steveastrouk (author)2013-09-05
Those are really pretty. I love the idea of astronomy themed jewellry. Lizzyastro has a broach in the shape of orion, with the key stars picked out in glass of the correct colours...
Thank you!
artfulann (author)2013-09-03
Beautiful! Guess I'll have to start using wire to make jewelry again! You inspired me.
Thank you!
Muhaiminah Faiz (author)2013-09-02
I love it! great work Emily, as always :)
Thank you!
Kiteman (author)2013-09-02
Lovely job, as usual!
ynze (author)Kiteman2013-09-02
+1
emilyvanleemput (author)ynze2013-09-02
Thank you :D
freetree123 (author)2013-09-02
Prety
thanks
Tarun Upadhyaya (author)2013-09-02
Super Cute !! Thank you for sharing.
Thank you!
About This Instructable
51,580views
942favorites
License:
Bio: Industrial Design student at Eindhoven University of Technology
More by emilyvanleemput:Evenstar Necklace3D Design As Tool for Jewellery MakingTriple Circle Wire Earrings
Add instructable to:
