Spiral Wall Lamp
Published
Introduction: Spiral Wall Lamp
The Materials
-120x120 plexiglass
-50cm led ( blue )
-2m power adapter
- glue
Plexiglass sizes
- 5 x 3x3 cm
5 x 4x4 cm
3x 5x5 cm
3x 6x6 cm
6x 7x7 cm
4x 8x8 cm
1x 9x9. cm
1x 10x10 cm
5x 12x12 cm
5x 13x13 cm
5x 14x14 cm
5x 15x15 cm
4x 16x16 cm
2x 18x18 cm
2x 19x19 cm
2x 20x20 cm
2x 21x21 cm
2x 22x22 cm
2x 24x24 cm
2x 25x25 cm
2x 26x26 cm
2x 27x27 cm
2x 28x28 cm
2x 30x30 cm
Step 1: Design Process
For starters, it is important to make a wide research about lighting from books and internet. Also having software knowledge is important for the design process.After making a wide research about lighting, I determined the concept and designed it on Autocad and 3Dsmax.
Step 2: Cuttıng and Glue On
I cut the plexiglasses according to the sizes by using cnc lazer. Then I enumerated them. I appropriately glued the plexiglasses each other. At the end of the my work , I created the project that I aimed.
Step 3: Mounting
It’s supposed to be mounted like a sconce, so mounted the lighting to the wall with a hook
Step 4: Led Researching
Then I made a color difference experiment and decided to go with blue LED’s. Because it is more interesting and brighter, also looks better than the other LED colors.
Step 5: Result
This is the result that I have after sketching, researching and testing process. This lighting has a different design and is being used like a sconce.
Step 6: Spiral Wall Lamp - Construction Stages
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    wowww its great !!! Rainbow
    thank you Muhaiminah :)
    Cool lamp! it looks great with blue LED color :)
