3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Spirit Of The Dead (Photoshop 7.0 or above)
Want to shock and scare your friends this Hallowe'en with the simplest of things, a photo?
With this tutorial I'm going to let you in on one of my secret techniques.
Why not? This is one of my favourite times of the year.
Step 1Selecting The Photo
Selecting The Photo
For this to work effectlively, you need to have a clear (preferrably high quality) image.
As you can see, it doesn't really matter about the darkness of the photo as you can fix this, all you need is a creepy pose would be excellent or even a blank pose works great. Head and shoulders works best as you can get up close and personal and see details such as they eyes (we will get onto that).
In my photo, I really opened my eyes so that the effect will really pop.
9 comments
Feb 18, 2012. 4:29 PMDustySeven7 says:
If you want to peeling/crumbling skin to blend and look creepier here is a tip. If you have not done so, create a layer that has only the skin. do this my selecting the skin area and pressing ctrl j to copy via new layer. hide the other layers. the skin layer will be slightly transparent. copy it 2-3 times and merge the copies. after this go to the channels. choose the channel that has the best contrast and copy to a new document. in the new document add a 2px gausian blur and adjust the contrast via levels (ctrl l) use only the middle and right markers.
save it as a psd with the name displacement map. switch to your original document. create a new layer and go to file>place>use you texture image. make sure you are still on the texture layer. after that go to filter>distort>displace. select the displacement map psd file you created. the texture will now me mapped the shadows and form of your models face. adjust the options to get the look you want and accept.
Feb 18, 2012. 4:14 PMDustySeven7 says:
For skin hue/pigment change. I select the the skin, feather the selection by 1px and copy via new layer ( ctrl j). click on the new layer and add adjustment layer hue and saturation. after you get the look you want click okay. while holding the alt key click between the adjustment layer and the skin layer. this will link the adjustment layer to only the skin layer. to enhance the effect. add a second adjustment layer with brightness and contrast. small tweaks on this layer. make sure the second layer is above the first. hold alt and click between the two adjustment layers. The second adjustment layer is now linked to skin layer as well.
This method is NON DISTRUCTIVE. meaning you can change or delete the effect and return to the original.
Nov 2, 2011. 8:32 PMDustySeven7 says:
for the copying they eyes to a new layer there is faster shortcut. With the eyes selected via laso etc press "ctrl" and "j". this is the shortcut key-command for copy to new layer
Oct 22, 2011. 4:42 PMkittigirl123 says:
haha, mine didn't come close to yours, and the background is cheesy, and i didnt have enough shadows. but great tutorial!
Oct 19, 2011. 2:58 AMHenry3009 says:
Wow! Really simple instructions that even I can follow - Cool!! I didn't know it could be so easy.
Oct 17, 2011. 1:13 PMscoochmaroo says:
Lots of great information here, even before you get to the zombification!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:FloFreek
Your friendly neighbourhood weirdo. Celebrating her individuality since 1648. NOX INVICTUS
