3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SplatterFX - Articulated Monster Frame
Step 5Assembly - Splivels
Assembly - Splivels
Assemble each of the Splivels - I have attached a pdf file of how they go together to help.
Each Splivel consists of:
2 - PVC end Caps (drilled)
2 - 1/4-20 x 1-3/4" Carriage bolts
1 - 1/4-20 x 1" Hex Bolts
5 - 1/4-20 Hex Nuts
6 - 1/4-20 Star Washers
2 - pre-cut Splivel plates (see step 2)
Repeat assembly for each Splivel - there is a total of 9 in this project. When assembling the End caps and Carriage bolts, make sure that you allow the bolt head to protrude as much as you can. This allows the joints to move freely with the plates. Make sure to tighten the nuts as much as you can and then drip PVC glue into the inside of the PVC cap (keep it off the sidewalls - you just want to make it so the nut can't back off).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:tiki_robot
