Because of the forces involved inside a typical rocket, and because PET plastic is very hard to glue, there are only a few existing glues that are suitable for the job. The most commonly used is PL Premium construction adhesive, but VISE and a small number of others can also be used.
Splicing is not as easy as joining bottles using a Robinson coupling, is permanent and is less predictable at which pressure it will fail, but it has the advantages of virtually unrestricted internal flow and potentially long pressure bodies can be made this way.
The technique presented here is based on previous work done by other rocketeers:
http://wrockets.trib-design.com/index.php?project=nick&page=splicing
In the following video tutorial we present a technique called 'symmetrical splicing' for joining two bottles. The same technique can be used for making much longer bodies. The join is just repeated for each section.
For more water rocket instructions visit: http://www.AirCommandRockets.com
Just as an estimated guess. What would you think this MOSS branded quad garden fitting would rate to? It appears to be cast steel coated in a golden layer. Ball valves look good. I was hoping around the 150PSI-200PSI mark.
I'm using this unit on this Quad metal launcher
The water rocketing community is in need of some good info.
I am sure everyone would love a write-up on how to build Polaron IV.
I was actually going to email you to request if I could use a shot of Polaron IV as the picture for my new water rocket group. Water rockets
Also sliding them over each other gives you less volume.
