about cost$
$25 Paint - qt primer - qt yellow - sample mold green - sample black - sample white - sample blue - paint marker red
[home depot sells pint samples for cheap.]
$45 14 - 1x4x8'
$20 3/4 Plywood
$4 Wood glue
$?? woodgrain plexiglass or ???
free imagination
misc. 1 1/4 screws - 2 1/4 screws - 3 3" flat brackets - paint brush and roller - artist brushes
tools- jigsaw - circular saw or miter box - sander or router - drill - and a projector if you can get one
Remove these ads by
Signing UpStep 1Building the frame
measure the mattress you are going to use, your framing will want to be about 1" bigger. pre drill with a counter sinking bit, and use wood glue every where you screw wood together. you can see in the photos i screwed wood slats across to support the mattress. i then screwed 2 1x4 together to make the corners [the height will vary with how tall you want it to be]. i then cut the horizontal pieces and decided to make some of them wavey with a jigsaw [as seen in photos]. also fastened the horizontal bottom pieces. i had a set of steps from another bed that i used but a simple ladder would work.
Are you intentionally torturing your offspring? :-)
Somebody had to say it. Nice work, though. Well done.
